April 30, 2026, 04:01:54 AM *
Author Topic: Anyone use this?  (Read 3436 times)
TallRider
Cape Coral, Fla
« on: June 26, 2017, 06:56:41 AM »
Bugs me all the time trying to check pressure and fill tires seems like it would help a lot.
https://www.harborfreight.com/automotive-motorcycle/lifts-stands/motorcycle-wheel-cleaning-stand-98800.html
1951 HD FLH Chopped
1978 Honda Goldwing
2005 VTX 1800
2014 Honda Valkyrie
hungryeye
Scottsdale AZ & Climax NC, formally freehold, nj
« Reply #1 on: June 26, 2017, 03:25:55 PM »
I have one, use it mostly for running rear wheel up on it to help lift bike on center stand, my 83 silverwing 650 has a poorly designed CS, helps alot. Have also used for front tire cleaning on various bikes. Well worth the $$ to have around, don't take up much space...well built.
2014 F6c Red ish
1983 GL650 cream puff
2010 Spyder RS
we DRIVE our cars, we RIDE our motorcycles!
TallRider
Cape Coral, Fla
« Reply #2 on: June 27, 2017, 12:48:13 PM »
I figure better than rolling bike around to get valve stems right to check pressure. I have the tire pressure monitoring system with the display mounted on the bars. Don't know if I loose some pressure with them but need to adjust pressure every 4 or 5 weeks. Getting the stems in right place annoying.  Thanks.
1951 HD FLH Chopped
1978 Honda Goldwing
2005 VTX 1800
2014 Honda Valkyrie
Adirondack Bill
Upstate New York Near Lake George
« Reply #3 on: June 27, 2017, 04:07:53 PM »
Tallrider- this looks  like just what I have been looking for make polishing rims quick and easy. I ordered one today. Thanks, nice find!
TallRider
Cape Coral, Fla
« Reply #4 on: June 28, 2017, 05:20:38 AM »
Got one too. Thats why I like cataloges vs going threw on line web pages.  They are Ok if you know what you want. In this case I was walking through the Harbor Freight store.  (We have 2 in Ft Myers)  The original store here in Ft myers  is on the south side  a ways for me to drive. but unfortunately they opened a new one, sort of a super store in North Ft Myers, Bad luck for me, now to convenient.  Cheesy  I talked to the mgr one day at the South store and he told me they were the largest volumn store in the US at that time. And a small store at  that. I walk down every  isle and some times see something that lites up  the bulb and there it is, just what I was looking for.
1951 HD FLH Chopped
1978 Honda Goldwing
2005 VTX 1800
2014 Honda Valkyrie
hungryeye
« Reply #5 on: June 28, 2017, 05:54:00 AM »
HF has a front wheel chock for $59ish. It looks almost as good as my $200 chock that came with my Razor trailer. First time I moved a bike on it with the chock I couldn't believe how solid it kept the bike, no worries now when I tow a bike to AZ now for the winter. If you ever tow or don't want a center stand for oil checks and cleaning, check out the HF $59 front wheel chock.
2014 F6c Red ish
2010 Spyder RS
« Reply #6 on: June 29, 2017, 03:58:44 AM »
Hey thanks for the heads up on this, Im going to get one.  cooldude
TallRider
Cape Coral, Fla
« Reply #7 on: June 30, 2017, 06:13:09 AM »
Store price was under 20 bucks, on line its listed for 22 bucks, got 20% in store as well. cooldude
1951 HD FLH Chopped
1978 Honda Goldwing
2005 VTX 1800
2014 Honda Valkyrie
Bill Havins
A roadster!
Abilene, Texas
« Reply #8 on: July 02, 2017, 08:00:31 AM »
HF has a front wheel chock for $59ish....If you ever tow or don't want a center stand for oil checks and cleaning, check out the HF $59 front wheel chock.
Hmmm.  I picked up one of the HF wheel chocks (the "$59ish" one).  On a trailer or bolted to the floor it might rate higher than a "C."  If it is used on concrete it will scoot across the floor when you try to ride the bike into place.  I ended up taking the pivoting "ramp" off and just position my front wheel against the forward stop.  I then attach tie downs to the eyelets on the stand and to my handlebars.
Regarding use with our Valkyries - be careful!  Tie downs will want to rub against the forward end of the radiator cowls.  I don't have the stock headlight and plastics on my bike now - I don't know how tie downs might work with those bits in place.
I give this Harbor Freight "chock" a sold "C" when used with an F6C.  It will work, but it needs to be changed a bit and, even then, is not a great design for use with these scooters.
It may go back to the store.
Bill
hungryeye
« Reply #9 on: July 02, 2017, 08:51:11 AM »
The one that came with my trailer is a Condor, about $250. I remember removing it from the trailer to test it before I use it on a 2000 mile trailer ride. It did the same thing as your el cheapo one did, runs away when trying to ride into it. I remember putting a 4' 2x4 against the unit flat on the floor and the other end touching the wall. Didn't move after that. I have a center stand so I only use it on the trailer.
2014 F6c Red ish
2010 Spyder RS
Bill Havins
A roadster!
Abilene, Texas
« Reply #10 on: July 02, 2017, 08:56:39 AM »
I think on your trailer it is the perfect design.  In the garage, not so much.
The HF unit is going back to the store.  I'll get a center stand and the "million dollar" left side exhaust protector (Honda part number 18417-MCA-A20).
Lesson learned.
Bill
hungryeye
« Reply #11 on: July 02, 2017, 10:06:36 AM »
There are tons of CS's on fleebay, look for one with most of the mounting hardware, I think I paid $40. Had to buy 1 screw and a spacer $8. I found a cheap heat shield fleebay also. Was scrufty looking in the pic but for $20 I gave it a try, it cleaned up fairly well, few scratches but not noticeable unless I pointed it out. Also check out a trike shop, they may trade for your non dimple shield for a dimple. With all your patience and skills, you can make a mold and pound the dimple in or cut a slot in it. I don't think a cut out would look that bad.
2014 F6c Red ish
2010 Spyder RS
Bill Havins
A roadster!
Abilene, Texas
« Reply #12 on: July 02, 2017, 10:27:39 AM »
.... With all your patience and skills, you can make a mold and pound the dimple in or cut a slot in it....
My biggest problem right now is time.  I have completely used up all of my free time and have almost used up the majority of my sleeping time.  Judy insists I have to cut back somewhere.  Wink
Oops!  Sorry about hijacking the thread.  Now back to your regularly-scheduled HF discussion.  Wink
Bill
« Last Edit: July 02, 2017, 05:38:08 PM by Bill Havins » Logged
goldstar903
« Reply #13 on: July 03, 2017, 08:00:14 PM »
I was going to say WTH, before Bill finally put this thread back on track. The thread started with a "wheel cleaning stand," and quickly became everything but.  2funny  crazy2
Tallrider, the wheel cleaning stand is a good thing! Thank you!
I love to go fast, but my wallet doesn't! Maybe I should leave my wallet home!
