February 13, 2026, 10:41:21 AM *
Author Topic: Running Lights  (Read 2029 times)
Harryc
Sebastian, Fl
« on: June 27, 2017, 06:55:48 PM »
So I was riding through Western Connecticut last Saturday, nice country roads and small New England towns. No less than three times, I noticed cagers starting to turn left directly in front of me (2 lane roads, they were coming in the opposite direction), then at the last moment they seemed to see me and pull back into their lanes. This seems to be a good story, but it has me thinking. How can I be more visible to oncoming motorists. I have a ridiculously bright Daymaker LED headlight already, but a friend recommended a headlight modulator. I am also looking for any suggestions on the best/brightest running lights to make the bike appear 'wider' and/or more visible. Thoughts? I am ready to invest in the best gear to be seen. Headlight modulators make sense, but I heard they are illegal in some states? Anyone know about NY or other N. Eastern States?
« Last Edit: June 27, 2017, 07:04:50 PM by Harryc » Logged
« Reply #1 on: June 27, 2017, 07:07:26 PM »
Harry, can't answer your question about the legality of modulating lights in NY, heck can't even answer about MA either, but I've been told in MA, as long as it isn't a blue flashing light, it's good.
I used to have a very lightly blue headlight bulb and that would get a lot of double takes, with some people in front of me, actually pulling over. Smiley
Never got called on it, it burned out and I never found another.  Didn't really look that hard.
I had lights mounted on my crash bars at one time, those are pretty spaced wide.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #2 on: June 27, 2017, 07:40:44 PM »
By Federal law, motorcycle headlight modulators are legal in all states.  I carry a copy of the statute just in case it's questioned.  http://www.americade.info/mod-law.htm
You have to buy one specific for LEDs if that's what you've got for a headlight.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #3 on: June 27, 2017, 07:44:11 PM »
from my post http://www.valkyrieforum.com/bbs/index.php/topic,89285.0.html
For safety, A Triangle Head Light Pattern
The results of the controlled field tests indicated
that the triangular lighting pattern used with each
type of auxiliary lights (crossing, ditch, and
strobe) increased detectability of the locomotive
compared with the use of the standard
headlights alone. Each system provided a
distinctive, uniform light pattern that motorists
could recognize as signifying a locomotive.
The crossing light system provided the best
overall performance. The increase in detection
distance provided by the crossing light system
(over that of the ditch and strobe systems and
the standard headlights alone) was statistically
significant, providing a greater safety margin.
ntl.bts.gov/lib/42000/42800/42871/rr0717.pdf
Harryc
Sebastian, Fl
« Reply #4 on: June 27, 2017, 07:44:50 PM »
@Valkpilot, good info, thanks. Any recommendation for a decent headlight modulator unit for LEDs?
« Last Edit: June 27, 2017, 07:47:07 PM by Harryc » Logged
Valkpilot
Corinth, Texas
« Reply #5 on: June 27, 2017, 07:50:14 PM »
Start here: https://kisantech.com/mag/
Google or Bing search for "led headlight modulator" will yield a ton of results.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Harryc
Sebastian, Fl
« Reply #6 on: June 27, 2017, 07:57:48 PM »
Thanks. From Kisantech this looks to be the correct unit for my application. https://kisantech.com/mag/pathblazer/p115w-h3-hd4.html
Harryc
Sebastian, Fl
« Reply #7 on: June 27, 2017, 08:19:56 PM »
Thanks Bill.
Hooter
S.W. Michigan
« Reply #8 on: June 28, 2017, 06:11:32 AM »
I  won't ride without them on my bikes. All 3 have them. (Passing / running whatever you want to call them) I have very little problem with people  pulling out in front of me. More light to the front the better.
« Last Edit: June 28, 2017, 06:15:52 AM by Hooter » Logged
« Reply #9 on: June 28, 2017, 10:54:55 AM »
so you're telling me loud pipes don't save lives?  Grin
« Reply #10 on: June 28, 2017, 11:27:16 AM »
People say I show up real well with motolights... it doesn't seem
so much like it with this old daytime picture that from an angle...
Here's Wimp showing up at a meet-up place in the daylight, he
has similar lights, much less expensive than motolights, they
work great I think...
I can see Stanley Steamer's pod lights on his Interstate really well.
I think "the triangle effect" of lights like these get notice  cooldude
Leathel
New Zealand
« Reply #11 on: June 28, 2017, 12:49:50 PM »
I have fitted these spots, same spots as I run on the 1100
http://www.ebay.com/itm/2X-2-10W-Cree-LED-Work-Light-Spot-Offroad-Driving-Fog-Lamp-Motorcycle-4WD-UTE-/172659144443?epid=625299959&hash=item28334976fb:g:1VgAAOSwGYVW9jYO&vxp=mtr
on the Valk i fitted them as wide as I could and my riding buddies recon they really stand out
this is with the spots only on, But I have since set them wider and higher, you can ride without the headlight if that blows Cheesy
Modulators are illegal in NZ Sad
I also thought about setting up the indicators as running lights like my old bike but not looked in to it yet, but having orange on as well should add to the package to stand out?
Harryc
Sebastian, Fl
« Reply #12 on: June 28, 2017, 02:02:07 PM »
Thanks Leathel. Did you wire them directly to the headlight circuit or did you use a relay with direct battery power and a switch? Your mounting system has me thinking too. I'd also have to do a custom bracket because I already have a lot going on with the crash bars between highway pegs and the Baker Air Wings already mounted to it.
« Last Edit: June 28, 2017, 02:32:57 PM by Harryc » Logged
Leathel
New Zealand
« Reply #13 on: June 28, 2017, 03:32:53 PM »
I have a switch block on my front brake master that activates a relay, picked up the power from the accesery wire behind the RH side cover.... I put a multi wire cable under the carbs when I had them out the first time so have 9 wires to  run power back and forwards.... makes it easy to add bits Cheesy
quick google for the switch block I have found this link, can be found cheaper though
https://www.rockymountainatvmc.com/p/1237/51191/Show-Chrome-Accessories-L.E.D.-Master-Cylinder-Switch-Block-Assembly
It would not be hard to get a relay feed from the park lamp and a small relay (if you can find one) would fit in the headlamp housing lamp.....just need a power source run forward
Harryc
Sebastian, Fl
« Reply #14 on: June 28, 2017, 03:45:27 PM »
Thanks. No 'park lamps' on US bikes and I already used the accessory circuit for my electronic fuel cutoff, but I could certainly use it to trigger another relay. Smiley Ideally if I do this I'd go with a fuse block that has a large relay for all of these switched accessories. Too many wires on the battery presently. I already have the horn, heated grips,  and battery tender hooked to the battery.
« Last Edit: June 28, 2017, 03:53:38 PM by Harryc » Logged
« Reply #15 on: June 28, 2017, 04:15:07 PM »
I have auxiliary lights that are actually small headlights that use H4 halogen bulbs. I run all three lights on high beam during bright daylight and have not had people turn in front of me.
Leathel
New Zealand
« Reply #16 on: June 28, 2017, 04:16:55 PM »
Yeah I have grips, 2 horns, fuel shut off, & spots, I have one main fused power that loops on to each relay but I have some pretty small relays I got from a wreck for the lower power needs, I needed a big relay for the horns though but one with twin power outs Smiley
Here is the size of the relays I am using
numbers from the relay
Harryc
Sebastian, Fl
« Reply #17 on: June 28, 2017, 04:23:01 PM »
@Leathel, thanks!. @Gryphon Rider, where did yoiu get that light bar?
Valkpilot
Corinth, Texas
« Reply #18 on: June 28, 2017, 05:22:29 PM »
Wiring diagrams for adding driving lights: http://www.valkyrieforum.com/bbs/index.php/topic,56705.msg546076.html#msg546076
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Harryc
Sebastian, Fl
« Reply #19 on: June 28, 2017, 07:51:35 PM »
@Valkpilot, thanks for the diagrams.  You guys are great. Thanks for all of the input and ideas.
« Last Edit: June 28, 2017, 07:53:58 PM by Harryc » Logged
« Reply #20 on: June 28, 2017, 10:08:21 PM »
I made it. 1" diameter aluminum bar and clamps from a local motorcycle accessory store.
h13man
Indiana NW Central Flatlands
« Reply #21 on: June 29, 2017, 07:46:01 AM »
I installed the same ones except in chrome finish on top the engine guards. Took some adjustments for night use as "tuners/lowriders" didn't like them.  Grin
On another note, I see you have Kury Premuim floorboards on the driver position. Are they mounted with Kury adapters  on stock mounts?
Harryc
Sebastian, Fl
« Reply #22 on: June 29, 2017, 09:21:53 AM »
Do you recall where you got them? I can't seem to locate that same light in chrome.
h13man
« Reply #23 on: July 01, 2017, 08:01:44 AM »
I believe I got them thru Amazon.
Harryc
Sebastian, Fl
« Reply #24 on: July 01, 2017, 01:18:07 PM »
Thanks. I actually found them but at 3 times the price on EBay.
h13man
« Reply #25 on: July 02, 2017, 04:55:50 AM »
I paid $60 for mine.
https://www.amazon.com/gp/product/B00J6990A2/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
I had a pair of 1 1/8" Kury Magnum clamps I revised to mount them. I tried the Kury "P" accessory clamps and was very dissapointed in the QC and fit in the 1 1/8" fit (sleeve fit) Shocked.
For the switching I used this: https://www.amazon.com/gp/product/B0195V8G4Q/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1 which is a extremely QC item and you can see the light on in the daylight.
« Last Edit: July 02, 2017, 05:11:28 AM by h13man » Logged
Harryc
Sebastian, Fl
« Reply #26 on: July 02, 2017, 06:23:03 PM »
@h13man, thanks!
Wayn-O
Orem, UT
« Reply #27 on: July 07, 2017, 01:15:24 PM »
@Gryphon Rider, please show us more pics of your aux lightbar setup.  I would love to copy what you've done.  Thanks!
2000 GL1500C Valkyrie
2003 VT1100C Shadow Spirit
1998 VT1100C Shadow Spirit
1983 VF750C V45 Magna
« Reply #28 on: July 07, 2017, 01:42:25 PM »
I'll get back to you in a few days.  I haven't even unpacked the bike from InZane yet, and I don't want to give you a bunch of close-ups of bug guts.  And I need to decide how to make my pics available in the near future, as Photobucket has just committed suicide, although they don't know it yet.  BTW, not asking advice on the photo hosting thing.
« Last Edit: July 07, 2017, 01:44:58 PM by Gryphon Rider » Logged
« Reply #29 on: July 07, 2017, 02:02:33 PM »
Grin you may not be asking, but I suspect you are going to get it.
DarkSideR
Pueblo, Colorado
« Reply #30 on: July 07, 2017, 02:12:05 PM »
Another option would be to upgrade to a LED headlight. I sell the adapter brackets making the conversion to the DayMaker headlights a possibility.
I suggest this not only because I can see better at night but because I am also much more visible during the day.
https://www.facebook.com/DayMakerBrackets/
https://www.youtube.com/watch?v=K48cp45_h6Q
Email me ValkyrieJosh@gmail.com if you are interested.
2001 Valkyrie Super Tourer
VRCC#34410
VRCCDS#0263
Harryc
Sebastian, Fl
« Reply #31 on: July 07, 2017, 02:15:30 PM »
Thanks Josh, already have your bracket and a very bright Eaglelights Daymaker. It was me who started the thread though ... obviously some folks need the bright light 'triangle of death' coming at them to wake up. Smiley
« Last Edit: July 07, 2017, 02:18:51 PM by Harryc » Logged
pancho
Bonanza Arkansas
« Reply #32 on: July 07, 2017, 02:45:32 PM »
I'm wondering if those 10w crees help light up the road any at night,, how much additional light do they provide?
Never mind,, I see you answered my question in the original post...
  " this is with the spots only on, But I have since set them wider and higher, you can ride without the headlight if that blows "
Think I will get a set to replace some small halogens that are mounted on the crash bar.
« Last Edit: July 07, 2017, 06:48:50 PM by pancho » Logged
