April 30, 2026, 05:22:58 AM *
Author Topic: Crankcase Breather  (Read 2563 times)
Adirondack Bill
Upstate New York Near Lake George
« on: June 30, 2017, 08:16:23 AM »
I finally got around to a little basic maintenance. I took the left cyclinder head side cover off to drain the Crankcase breather. Boy, what a pain in the Arce. I really should get a proper cycle lift so I don't have to lay on the garage Floor! It would have so much easier if the bike was 3 or 4 feet off the ground. At any rate, the breather tube was bone dry. In the past on other bikes, I usually find a couple drops of moisture, not on the Valk. Is this Normal? The hardest part of the whole project was getting those tiny rubber plugs back into the bolt heads. One of them flew off somewhere in the garage, I will have to buy a couple spares.
« Reply #1 on: June 30, 2017, 09:01:58 AM »
I thought the tube hanging down under the bike (rt side) with the plug and spring clamp on it was the crankcase breather drain.  At least on the 1500.
Also called the drool tube.
« Last Edit: July 01, 2017, 04:54:47 AM by Jess from VA » Logged
« Reply #2 on: June 30, 2017, 06:37:03 PM »
Glad you posted this Bill its a reminder to check mine. I haven't checked it in awhile.
