February 13, 2026, 10:40:44 AM *
Author Topic: Radiator heat shield  (Read 1295 times)
Karlos263
« on: July 05, 2017, 11:13:16 AM »
Ive been trying to reinstall the radiator heat shield. Been working on it all day with no luck. I even cut it in half to try that. I'm not sure anymore which is front or back or top or bottom or where it is supposed to go on the frame. There is nothing in the manual at all. Any help?
pancho
Bonanza Arkansas
« Reply #1 on: July 05, 2017, 11:31:05 AM »
It's easiest with the carb bank out of the bike or the radiator and fan moved,,, I messed up last time I had the carbs off and assembled out of order. I left it out and have had no adverse problems so far.....
Karlos263
« Reply #2 on: July 05, 2017, 01:19:29 PM »
I have the carbs out. I should have taken a pic first so I know how it should sit
Bone
« Reply #3 on: July 05, 2017, 01:37:15 PM »
Do a search on "reinstall the radiator heat shield " I got a couple of hits.
« Last Edit: July 05, 2017, 01:40:19 PM by Bone » Logged
Roidfingers
Tuscaloosa, Alabama
« Reply #4 on: July 05, 2017, 01:44:18 PM »
The two dog ear looking corners go down. At both sides slide under the frame and toward the front. The hump at the bottom is what goes over the thermostat housing.
Ramie
2001 I/S St. Michael MN
« Reply #5 on: July 06, 2017, 01:21:11 PM »
I spent a couple hours once trying but put it in backwards and had the same thought.
Roidfingers
Tuscaloosa, Alabama
« Reply #6 on: July 06, 2017, 03:20:16 PM »
Here is a picture and that's how it goes in.
http://www.partzilla.com/parts/search/Honda/Motorcycle/1998/GL1500C+A/RADIATOR/parts.html
Steel cowboy
Spring Hill, Fl.
« Reply #7 on: July 06, 2017, 06:05:22 PM »
I bought my interstate with the heat shield removed by the P/O. When stuck in traffic, or coming down from a high speed run the bike would start to rev up by itself as high as 3000 rpm. I would have to turn her off and wait for her to cool down, before starting up and continuing on my ride. I live in Florida and using a digital thermal thermometer I checked on carb's 1 & 2 and found them to be at about 227' when she would start to rev up. After installing the a heat shield the problem went away. Retesting I found the 2 front carb's to be below 200.
Say what you want but mother Honda felt it needed the shield that's why it's there. I put it on before reinstalling the carb's after I desmoged her. I desmoged her just to get rid of extra vacumm lines and extra plumbing and no other reason.
2001 black interstate
2003 Jupiter Orange wing
« Reply #8 on: July 06, 2017, 10:35:57 PM »
Keep in mind the next time you feel the urge to pull the carbs, you don't have to pull that heat shield. Just remove one of the engine hangers and slide them out that side. I usually do both hangers, gives more room and less cussing, and the engine isn't going to fall to the ground.
pancho
Bonanza Arkansas
« Reply #9 on: July 07, 2017, 01:08:29 PM »
After reading that, I'll put it back in next time I have things apart,,, never checked any temperatures, but hasn't acted up so far.
