February 13, 2026, 11:59:00 AM *
Author Topic: driver peg adaptor  (Read 2362 times)
six pack
Quispamsis New Brunswick, Canada
« on: July 08, 2017, 07:31:21 AM »
I should leave well enough alone  Sad I want to change out the OEM front pegs and replace with Kury 4450.  well I got the kurys but won't fit apparently  they require an adaptor... I am unable to find the correct one... any info as to the correct item #.??  also trying to put back oem peg I don't know how the spring is supposed to align.. any help GREATLY appreciated ,  I think these foolish jobs I tackle are above my pay scale,  just say'in     Smiley   TIA.
« Reply #1 on: July 08, 2017, 08:47:18 AM »
Kury sells an adapter for Valks. Contact them directly for the right one.
« Reply #2 on: July 08, 2017, 08:59:33 AM »
Here you go.  http://www.kuryakyn.com/products/1597/tapered-peg-adapters
For Valk front application:  Kuryakyn Front ISO Footpeg Adapters - Part No 7946
The adapters for front and rear Valkyrie application are different part numbers.
https://www.denniskirk.com/kuryakyn/iso-peg-adapters-7946.p493218.prd/493218.sku
https://www.amazon.com/Kuryakyn-7946-Front-Peg-Adapter/dp/B003O6XCF2/ref=sr_1_1?ie=UTF8&qid=1499529963&sr=8-1&keywords=kuryakyn+7946
EDIT:  Kuryakyn 4450s are MALE MOUNT ISO Wings which will not work on Valk at the drivers position.  At that position, you have to buy ISO Wings without ends, and the adapters (above).  Male mounts will only work at the Highway peg position, with the proper arms and/or clamps bolted to the engine guards.
ISO Wings without ends (plus adapter at driver position).
Male mount ISO Wings (for highway pegs only).
« Last Edit: July 08, 2017, 09:08:06 AM by Jess from VA » Logged
Harryc
Sebastian, Fl
« Reply #3 on: July 08, 2017, 09:31:26 AM »
I have an extra set of the 7946 adapters. PM me your address and I'll mail them to you. US lower 48 only.
six pack
« Reply #4 on: July 08, 2017, 10:04:02 AM »
well, I'm in deep dodo now.  I got the male mounts Angry   my $$$ loss,  I guess I will try to adapt them for hi-way pegs,  and look for floor boards,  any idea how that dam spring goes in the OEM peg....   thanks for the info everyone  Sad          Smiley
Harryc
Sebastian, Fl
« Reply #5 on: July 08, 2017, 10:24:54 AM »
Aren't the male mounts removable? There should be a long allen bolt running through the peg. Remove it
« Reply #6 on: July 08, 2017, 11:46:28 AM »
Don't you have a bike you can look at for the spring mount?
I'm fairly sure that the spring presses the peg down, so when taking a hard corner, the peg is being pressed onto the pavement. This will allow it to flex up, and not fit with your foot when you try to place it on the peg, by lifting up.
six pack
« Reply #7 on: July 08, 2017, 12:14:12 PM »
Yes HarryC  they are,   yea  Smiley.  just need  the7946 adaptors, thanks for your offer, but I'm in Canada and shipping costs would probably be more than the item.  I can get them from fortnine for 80.00 CDN shipped to my address.........Great bunch of guys in this Valkyrie group.   Smiley
Harryc
Sebastian, Fl
« Reply #8 on: July 08, 2017, 12:17:20 PM »
Awesome, let us know how you make out.
« Reply #9 on: July 08, 2017, 01:45:52 PM »
Sorry I misled you, I did not know Kury male mounts could be removed.
six pack
« Reply #10 on: July 08, 2017, 03:48:22 PM »
hey Jess, me either   Smiley.  but now we know..... the rest of the story.... cooldude
« Reply #11 on: July 08, 2017, 05:41:30 PM »
Kuryakyn is the king of interchangeability of parts.  But many (most) male mount Harley parts are cast as a single unit.
« Reply #12 on: July 09, 2017, 11:39:17 AM »
Sixpack, you should add your location into your profile.
For me, it's a 30 min ride across the border. I get items sent to a mail house just on the other side.
six pack
« Reply #13 on: July 09, 2017, 12:34:09 PM »
well I live in N.B. about 1.5 hours from Calais Maine, and I have had items sent there, usually we would make a day out of it with friends and food... but with the dollar difference ... sometimes  less expensive here.  Wink
« Reply #14 on: July 09, 2017, 02:53:38 PM »
Yah, you really need to know your prices before buying things from the US. Then add the cost of the travel, time, etc.. sometimes it just isn't worth it. But I just got a used Auston tire for $50, well worth the shipping and effort to get it.
six pack
« Reply #15 on: July 14, 2017, 06:20:30 PM »
well, I installed the 4450, with the 7946 adaptors and find the pegs too high, so I reversed the adaptors and it seems better but now the springs have no pressure and the pegs just "flop" loosely....any suggestions..      ???  plus I added a "blackbird" shift lever...
Harryc
Sebastian, Fl
« Reply #16 on: July 14, 2017, 07:26:52 PM »
Should be the same height as the OEM Valk pegs..I don't get it. Do you need a peg lowering kit?
six pack
« Reply #17 on: July 15, 2017, 05:13:52 AM »
maybe a lowering kit would help... a few years ago I had a 98 Tourer with floorboards and rattlebar shifter and lowering kit,  and I don't remember having this "too high" problem, other than scraping the pegs easily Smiley . the bloody things are expensive  $$$
« Reply #18 on: July 15, 2017, 06:42:51 AM »
MarkT sells some for a good price. They are powder coated on the left side though, no chrome.
« Reply #19 on: July 15, 2017, 11:22:52 AM »
Couldn't you place the springs back in in reverse so they are now installed wrong and applying pressure in the direction you want it to?
six pack
« Reply #20 on: July 15, 2017, 02:59:08 PM »
tried that ,  wouldn't work,  peg just flops....
six pack
« Reply #21 on: July 17, 2017, 08:57:03 AM »
what is the correct orientation for the pegs?? I have the chrome end to the front and I find my shifting foot catches the rubber and is lifting them, anyone else have this problem.  Sad  I starting to think that the OEM's might go back on, very disappointed...  Undecided
Harryc
Sebastian, Fl
« Reply #22 on: July 17, 2017, 02:33:06 PM »
Can you post a pic? As you are looking at the top of the peg, the chrome showing in one corner goes toward the rear of the bike.
six pack
« Reply #23 on: July 17, 2017, 04:08:43 PM »
I have the chrome end toward the front....I don't know how to post a picture..... above my pay grade I guess   Grin
Harryc
Sebastian, Fl
« Reply #24 on: July 17, 2017, 04:21:12 PM »
I was thinking of different pegs. For the ISO wings the chrome end goes towards the front of the bike.
six pack
« Reply #25 on: July 18, 2017, 12:39:49 PM »
well I went and reversed the 4450's and removed the blackbird shifter and reused the OEM shifter...
much more tolerable now, I will give this set up a try,  if it doesn't work for me, I will use OEM pegs with blackbird shifter and give that a try.... or maybe explore floorboards..... Undecided
