February 13, 2026, 10:41:23 AM
Found my squeak
Topic: Found my squeak (Read 1265 times)
Bronxboy
Tampa Bay FL
Found my squeak
July 08, 2017, 04:33:35 PM »
https://goo.gl/photos/eMeHeUTQDj1qLteB7
While out in Colorado, I started to hear a squeak coming from the rear of the bike but I couldn't pinpoint it. Thought it was the brakes, because when I put a little pressure on the rear brake, the noise went away.
Boy I was wrong, just glad it held up until we got back. Not sure why it failed as the bearings were only 2 yrs old, put them in when I had wheels powder coated.
https://photos.app.goo.gl/Z8XVCYBWHGEvRSvL2
Re: Found my squeak
July 08, 2017, 05:51:12 PM »
Your balls are showing.
Re: Found my squeak
July 08, 2017, 07:12:42 PM »
Nick, have you done the bearing mod on the rear wheel? The left bearing...change from a single row to double row with a cut down spacer(see Grumpy) and no dust cover.
flash2002
Montreal, Que
Re: Found my squeak
July 09, 2017, 02:47:48 AM »
I did the mode on my bike and did reinstall the dust cap, I just glued it on with silicone never came off.
Bronxboy
Tampa Bay FL
Re: Found my squeak
July 09, 2017, 05:18:13 AM »
Quote from: John Schmidt on July 08, 2017, 07:12:42 PM
No I have not, I already pressed in new bearings.
Tfrank59
'98 Tourer
Western Washington
Re: Found my squeak
July 10, 2017, 03:51:07 PM »
In almost every Thread about failed wheel bearings somebody mentions it so I should that if the spacer between the inner races inside the Hub isn't snug against those races you'll have a side load on the bearings that'll cause a premature failure. Methinks the installation of wheel bearings is every bit as critical to bearing life as which bearing you buy provided it's the right size and all
-Tom
Keep the rubber side down. USMC '78-'84
