March 06, 2026, 09:50:09 AM *
Author Topic: any way to delete a post?  (Read 3490 times)
sugerbear
wentzville mo
« on: March 04, 2009, 07:07:18 PM »
Joe Hummer
Arnold, MO
« Reply #1 on: March 04, 2009, 07:13:21 PM »
Yes...and No...
You can not delete the original post in a thread if someone else has posted a reply.  For that, you will have to ask a Moderator to remove the post or delete the post before someone replies to it.  You can delete replies you made to someone else's thread.
To remove the post, open the thread, find your post, then click the Remove link in the upper right corner of your post.
Joe
1999 Valkyrie Interstate
PAVALKER
Pittsburgh, Pa
« Reply #2 on: March 04, 2009, 07:14:00 PM »
Yep....  as the originator of the post above, YOU should be able to remove it or edit it, provided you are logged in.   Look at your post above and to the right of the title you should see....   Quote    Modify     Remove.    Hitting the remove tab  should do it.
try and let me know
EDIT.... JoeValkIS is correct....  the first post can only be deleted by admin or a moderator.  I tried to do it on an earlier post of mine.
« Last Edit: March 04, 2009, 07:20:15 PM by PAVALKER » Logged
John
Cowbell
I need more of it.
Huntington, WV
« Reply #3 on: March 04, 2009, 07:22:57 PM »
If all else fails, just hit edit and erase everything you said and/or replace it with something else.
'04 Mazda RX8 - 13B 6 Port - Agency Power 3" Catless Midpipe & 3" Catback
'89 Toyota Supra - 7MGTE - .57 Trim Driftworks Turbo - HKS Metal Headgasket - Exedy Camgears - Megan Racing Downpipe - 3" Straight Exhaust - GodSpeed FMIC - TurboXS Type H BOV - SPEC Stage 3+ Clutch
Joe Hummer
Arnold, MO
« Reply #4 on: March 04, 2009, 07:29:07 PM »
Only if someone has posted a reply.  If it is still only your post...then you can remove it as indicated.
Joe
