February 13, 2026, 11:59:03 AM *
Author Topic: Wrench size for bag hanger  (Read 1017 times)
baird4444
« on: July 18, 2017, 11:20:51 AM »
I am doing my spline maint and installing a hitch while I'm at it. What size wrench is needed
for the front bolts on the fender rail? going to have to buy a thin walled as well to get
inside the bag hangars....   14mm won't quite get on it, is it a 15mm thin wall?
     thanks in advance- Mike
    - ya gotta be SOBER!
     -Cody Baird
« Reply #1 on: July 18, 2017, 11:32:43 AM »
Try the open end wrenches that come in the OEM tool kit.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #2 on: July 18, 2017, 11:54:23 AM »
On mine, it's a 17mm.  An 11/16 inch will work but is a little loose.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
baird4444
« Reply #3 on: July 18, 2017, 11:56:18 AM »
recessed in the hangar, NO-GO
     -Cody Baird
« Reply #4 on: July 18, 2017, 12:08:34 PM »
Use a thin walled socket. If there's no clearance, remove the bag off the bracket. Takes an 8 mm socket inside the bag.
« Reply #5 on: July 18, 2017, 12:59:24 PM »
Are we talking about a Tourer or a Standard with aftermarket bags?
If you're installing a hitch, aren't you removing the bags?
baird4444
« Reply #6 on: July 18, 2017, 10:01:11 PM »
standard, these are just the soft bag supports. will try a pic in morning.
will keep bags after hitch install.
     -Cody Baird
baird4444
« Reply #7 on: July 19, 2017, 11:46:33 AM »
no luck on pic, Walgreens changed so I don't have link...
thinking a hacksaw or dremel and just remove that outer sleeve....
     -Cody Baird
