February 13, 2026, 11:58:58 AM *
Author Topic: Odometer memory  (Read 770 times)
Stick
Sherbrooke Nova Scotia
« on: July 23, 2017, 06:11:13 PM »
If the speedo cluster is changed out does it change odometer to new speedo numbers or is mileage memory retained in bike cpu?
2001 Valkyrie Interstate Burgundy/Black*Sold*
2000 Valkyrie Interstate-Black*Sold*
2000 Valkyrie Supervalk-Blue/Silver*Sold*
Steel cowboy
Spring Hill, Fl.
« Reply #1 on: July 23, 2017, 07:42:56 PM »
If it's an interstate the speedo memory is retained in a chip on the speedometer motherboard cluster itself. Changing the speedometer will show the donor's bike odometer.
2001 black interstate
2003 Jupiter Orange wing
« Reply #2 on: July 23, 2017, 09:13:14 PM »
It can be reset  to zero if so desired I have seen it done. Dont ask me how cuz I dont know but have seen a 2001 that was rebuilt and speedo only
Showed mileage sonce rebuild.
Steel cowboy
Spring Hill, Fl.
« Reply #3 on: July 24, 2017, 04:08:22 AM »
There are computer programs that when hooked up to the device will reset an automobile odometer. You can look it up on U tube. I purchased a speedo in the classified section here, because my trip odometer option was not working. But I found out the PO for some reason had the rubber plunger in the center of the cluster backwards. When I installed the spare speedo the odometer had triple what mine has. That's when I noticed the rubber plunger on his. Now all is good with my trip odometer too.
