February 13, 2026, 12:20:45 PM *
Author Topic: Horn  (Read 861 times)
Whitey
« on: July 29, 2017, 09:30:22 AM »
 Hey guys I was wondering does the horn work on positive side or thr ground side? Thanks
WintrSol
Florissant, MO
« Reply #1 on: July 29, 2017, 10:56:59 AM »
One side of the horn goes to ground, the other to the switch, which provides power.
Whitey
« Reply #2 on: July 29, 2017, 12:38:31 PM »
I seen that! I'm hooking up an air horn and got to hook positive from switch to relay! Wondering if I have to hook up grond or just leave it? Cause relay is already grounded!
Harryc
Sebastian, Fl
« Reply #3 on: July 29, 2017, 12:59:08 PM »
Yes you want to hook up the stock horn wiring (both 12v and ground) to the relay. If you don't do this the handlebar horn switch will not work. It needs a ground, and the relay needs to see the switch when pressed. The horn switch will trigger the relay will trigger 12v directly from the battery to the air horn.
« Last Edit: July 29, 2017, 01:02:48 PM by Harryc » Logged
