February 13, 2026, 01:39:29 PM *
Author Topic: questions on rebuilding 416 shocks update  (Read 1401 times)
matt
Derry New Hampshire
« on: July 29, 2017, 05:46:30 PM »
Hello so I know botto. Seal can be done as I have done those before. My question is they give o ring in kit to do seals uuner  eyelet anyone do those?
I was removing rear tire so I  took lower bolts out and started to lower tire and swing arm when shifter side shock fell apart. Top eyelet and approximate 6 inch threaded shaft stayed connected to bike. I called progressive they say catastrophic failure. Well I grab other shock and I can turn eyelet i can turn eyelet with my hand. So once again I call progressive and they say you should not be able to do that, so I ask if I replace those seals do I just tighten eyelet till it is tight, reply sir you need to send shocks to us as you should not touch that part unless you are authorized.
Sorry so long but I needed to ask before I start just diving in and seeing how they are assembled
Matt
They do come apart, but damper is a sealed unit and it is inside that were part failed
« Last Edit: July 30, 2017, 11:46:45 AM by matt » Logged
« Reply #1 on: July 29, 2017, 06:51:34 PM »
I believe u have to compress the top canister similar to this,
https://www.youtube.com/watch?v=Kykytty4rWY
this is what they look like when apart.
http://www.ebay.com/itm/PROGRESSIVE-16-4050-16-4050-KIT-B-DAMPERS-GL1100/272757110974?_trksid=p2481888.c100675.m4236&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D743f00487360476fab05823fd0f6dcf0%26pid%3D100675%26rk%3D2%26rkt%3D15%26sd%3D172757108470&_trkparms=pageci%253Ac668c4db-74ca-11e7-a741-74dbd18059e4%257Cparentrq%253A9138991415d0ab66c990b081ffff9939%257Ciid%253A1
« Reply #2 on: July 30, 2017, 04:56:33 AM »
Matt
Don't dive in at all.  Once you do they probably won't honor the warranty.  Box them up and send them back.
matt
Derry New Hampshire
« Reply #3 on: July 30, 2017, 05:46:19 AM »
They only have a one year warranty,  it has long been over.
RDKLL
VRCC #1231 VRCCDS #271
Mesa, AZ
« Reply #4 on: July 30, 2017, 01:40:56 PM »
I was getting ready to post about the lifetime warranty but it is only 1 year on some p/n's...
*All products are covered by a 1 year limited warranty (including tools, 12, 13, 14 series dampers, 412, 512, 413, 416, 716, 422, 425, 429, 465) (except those listed below) All springs, including spring only kits and springs installed in or on other products, are covered by a Lifetime Limited Warranty. All Monotube Kits, 430, 435, 444, 944, 970, 490, 990 series products are covered by a Lifetime limited warranty. 428 Series shocks are covered by a 2 year limited warranty.
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #5 on: August 02, 2017, 04:16:10 PM »
I have a question.  Since the 444 is NOT listed as a shock for our beloved valkyrie, how woild you send back for warranty if something did go wrong??
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
matt
Derry New Hampshire
« Reply #6 on: August 02, 2017, 07:31:40 PM »
What valkyrie?   They list the bikes they fit guess you own one of those. But then again they are listed on every site I have looked up as fitting  the valkyrie
Matt
« Reply #7 on: August 03, 2017, 04:15:21 AM »
Michael
I think if you have the receipt for new purchase, and send it and the worn out shocks in for warranty replacement, they'd just replace (or repair) it/them.
I doubt they'd ask what you were running them on.
I suppose if they did ask, it would be prudent to not tell them they were on a bike they (allegedly) weren't designed for.
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #8 on: August 04, 2017, 10:34:23 AM »
Michael
Michael
