February 13, 2026, 12:21:42 PM *
Author Topic: U-Joint Rebuild  (Read 939 times)
mrgeoff
My 99 CT..."Liahona"
Augusta, GA.
« on: August 01, 2017, 08:00:10 PM »
Was wondering if some one knows a part number for the cap bearings on the U-joints...??? If we can find out what size they are then we can at least try to replace the bearings if our U-joints go bad...like we do with car U-Joints...!!!
mrgeoff/SANDMAN
da prez
Wilmot Wi
« Reply #1 on: August 01, 2017, 08:08:51 PM »
  A while back , someone made a fixture for installing a car U-joint. I do not remember much more.
 It was then a re buildable joint. The OEM are staked and non serviceable as is.
                                         da prez
« Reply #2 on: August 01, 2017, 08:16:16 PM »
This was all attempted back around 2013-14', when u-joints where not available new. Someone did find a shop who would change out the u-joint in the yoke, but there where also reports of failures after only 5-10K miles.
For the time/cost, it is still not much more just to buy the OEM.
Now, if you can find a complete yoke that swaps out with ours, then you might have something. It was one or the other, a CR-V 05' (?) that might have matched.
A search should help out.
old grouch
Colorado Springs, CO
« Reply #3 on: August 02, 2017, 05:39:11 AM »
See this thread.     http://www.valkyrieforum.com/bbs/index.php/topic,30570.0.html
09/11/01 NEVER FORGET!
