February 13, 2026, 01:39:41 PM *
Author Topic: Steering stem tool on eBay  (Read 1120 times)
Hacked Valk
« on: August 03, 2017, 11:13:54 PM »
http://www.ebay.com/itm/GL-1800-Steering-Stem-Socket-Wrench-/162361769422?hash=item25cd83fdce:g:nQAAAOxy4dNS3YGb&vxp=mtr
It lists all years of the 1500 GoldWing as being compatible.  I thought the GW used the same tool as the Valk, but if I type in the Valkyrie info in the boxes to check compatibility it says it isn't. Compatible with the Valk? Yes or No.
The problem with humanity is: we have paleolithic emotions; medieval institutions; and God-like technology.
flash2002
Montreal, Que
« Reply #1 on: August 04, 2017, 04:26:52 AM »
Hi, just buy a 36MM socket and make your own. It's  simple to make, tape around the socket  mark where the tabs are and grind out in between the tabs.
NEHI
« Reply #2 on: August 04, 2017, 05:25:35 AM »
   I use the same socket for both my Valk and Goldwing 1500.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #3 on: August 04, 2017, 07:23:44 AM »
Just bought one for my collection. Online dealers still have them available, but they're $120.
Hacked Valk
« Reply #4 on: August 04, 2017, 08:13:52 AM »
Okay, thanks. Going to get one.
« Reply #5 on: August 04, 2017, 09:33:17 AM »
Exactly what I did a number of years ago. Socket was $3-4, marked it off using a spare nut I have, quickly found out a hacksaw was useless on that steel so used my die grinder. An hour later I had a steering stem socket for $3 and an hour of my time. Make all the vertical cuts first to outline the prongs, then make the horizontal cut between them. Dress up the cut out area with a grinder and it looks just like the $120 item....for $117 less.
Hacked Valk
« Reply #6 on: August 04, 2017, 10:23:08 AM »
I would indeed have made my own if I had to buy OEM.  Just figured the $35 including shipping was an ok deal as I would have needed to buy a grinder to DIY.
« Reply #7 on: August 04, 2017, 04:57:57 PM »
I understand!  cooldude  Keep in mind, they're not that expensive and can be used for many different jobs around the house. I recall about ten yrs. ago the lady next door couldn't get her old leaking kitchen faucet set out in order to install a new one. It had been place for nearly 25 yrs. and the fixture underneath the sink was rusted and wouldn't move. She asked me for ideas, so I told her to open her kitchen window which faced our garage side entrance. I ran an air hose over and through her window, a few minutes later I'm reeling it back up and she is holding the old fixture all cut up with my die grinder. She baked me a double batch of chocolate chip cookies in payment.....so see, it pays to buy a die grinder.  Grin
