February 13, 2026, 04:07:01 PM *
Author Topic: ContiGo 130/90-17 review  (Read 1306 times)
« on: August 11, 2017, 03:56:13 PM »
this is a rear tire installed on front in reverse. It had Quad Boss sealant-balancer installed.
Just changed it out with 26012 miles on it, which is pretty good for a V-Rated tire.
This was at and below the wear bars.  It was still safe for wet conditions at 25500 miles which I actually rode in, was a lite rain, but tire still had good grip but stayed at reduced speeds.
Next tire will be Dunlop D404 H-Rated, same size and will install the same way.  Should see 40+k miles based on other riders.
« Reply #1 on: August 12, 2017, 07:39:14 AM »
 I just removed a 404 from you IS, I hated it.  Noisy, vibrated and cupped badly.  I also have one on my standard, same thing.  I replaced the IS tire with a bridgestone battleaxe,  much better.   I would stay away from the Dunlop.  YMMV.
« Reply #2 on: August 13, 2017, 06:00:36 PM »
  I'm surprised by your assessment.  I've put tens of thousands of miles on several rear Dunlop D404's, on the front, reversed, without  issue.
mark81
Cincinnati Ohio
« Reply #3 on: August 15, 2017, 08:45:18 PM »
I have a 404 front on mine. Best mileage of all the tires ive had so far but id gladly sacrifice those few thousand extra miles ,the poor ride quality, insecurity i feel in turns and inclement weather, and the chunk of money i saved  for just about any other tire but a shinko 890.  The only other tire ive run i liked less than the 404.   Hope the rear on front works better than the front on front
1997 Honda Valkyrie
1981 Honda CB750 Custom
Bone
« Reply #4 on: August 16, 2017, 03:22:19 AM »
I've been running the 404 Front on my Valk and love the tire.
Here is the mileage I changed the tires;
14838
14430
14432
16285
15674
There were 3 more I've logged 123k miles on the 404 Front.
« Reply #5 on: August 16, 2017, 06:48:57 PM »
it will be a rear 404 of front, not a front 404
