February 13, 2026, 02:05:40 PM *
Author Topic: COOLANT LIGHT FLICKERING  (Read 1168 times)
svsteve
VRCC #1143
Lehighton,Pa.
« on: August 13, 2017, 02:09:12 PM »
I was out for a ride today and my coolant light came on. It stayed on for about a minute then went off. Now I see it flickering at times. Also , when I turn the key on it just flickers for a second, then goes off. The oil light and side stand light stay on, but coolant light doesn't. Any thoughts on this.
Steve
« Reply #1 on: August 13, 2017, 02:57:08 PM »
As a guess, you have a '97-'99 Valk. The early coolant lights had failures like this due to a module failing. It was corrected sometime in '99.
svsteve
VRCC #1143
Lehighton,Pa.
« Reply #2 on: August 13, 2017, 03:00:42 PM »
It is a 97. Do you know what module this would be? Or what it is called to get another.
Steve
klb
Hickory nc
« Reply #3 on: August 13, 2017, 04:23:03 PM »
Check this old thread out. It explains it.
http://www.valkyrieforum.com/bbs/index.php/topic,78286.msg766612.html#msg766612
cheeseman1969
Hastings NE
« Reply #4 on: August 13, 2017, 05:23:00 PM »
I just had this about 3 weeks ago. A old guy who owns a shop in Goodland KS told me to check the coolent. Fill it to the brim and then run it. I came on three more times in the next 60 miles and since (about 500) nothing.  Check that before doing the module thing. I got air in it when I went up Pikes Peak. If you did hills over 10-15 degrees you might of gotten air. It was a air bubble in my lines is all.
Gary "Cheeseman"
USN "weather guesser" Retired
Been everywhere...
« Reply #5 on: August 13, 2017, 07:34:32 PM »
Don't understand how going up a hill would get air in a Closed System? Must be me but seems impossible Undecided
WintrSol
Florissant, MO
« Reply #6 on: August 13, 2017, 08:41:00 PM »
I suppose that, if the reserve tank is very low (well below MIN), and you allowed the system to cool with the bike pointing up a steep enough hill, it could draw air as the coolant shrinks.
cheeseman1969
Hastings NE
« Reply #7 on: August 14, 2017, 12:10:27 PM »
Mine was not low BUT the hills going around the corners at Pike Peak was very steep. LIke over 20% I guess. So that is about the only way that I can figure that air got in. After I got home, I checked it again and it was lower so there was air in it.
Gary "Cheeseman"
Been everywhere...
svsteve
VRCC #1143
Lehighton,Pa.
« Reply #8 on: August 14, 2017, 01:51:14 PM »
Thanks klb, I printed this out for future if needed. I bought my bike in 97 and never heard about the issue with the temp module.
cheeseman1969, funny you say that about going up hill. I was going up hill when I seen my light on. Then last night I pulled my side cover and my coolant is down to the min. mark. I'm gonna try toping it off and see how that goes.
Thanks Guys
cheeseman1969
Hastings NE
« Reply #9 on: August 14, 2017, 01:56:10 PM »
I would open your raditor too and add it to the brim. I betcha that after you ride it a bit, there will be air in that radiotor cap.
Gary "Cheeseman"
Been everywhere...
