February 13, 2026, 02:05:39 PM *
Author Topic: Stock Petcock Removal. . .  (Read 1215 times)
Kunkies
Charlotte, NC
« on: August 13, 2017, 02:16:28 PM »
Quick [leading] question. . .  Roll Eyes
After 50,000 miles, I replaced my stock petcock with a Pingel "fuel valve" model 1311-CHV.  When I removed the the stock petcock I was surprised it was just a tube and valve on a 22MM mount.  Should there have been a screen or something like the Pingel, or did I leave a stock petcock remnant in my tank that could eventually cause a future fuel flow issue?
Thanks in advance for your input
« Reply #1 on: August 13, 2017, 02:37:14 PM »
Unless someone else took it out...
svsteve
VRCC #1143
Lehighton,Pa.
« Reply #2 on: August 13, 2017, 02:42:03 PM »
when i rebuilt my stock petcock I replaced the screen also. #4 on above diagram. Unless someone took it out, its in there.
Kunkies
Charlotte, NC
« Reply #3 on: August 14, 2017, 01:34:22 PM »
Ugh, I was afraid of that.  Gives me an excuse to empty my tank
Ramie
2001 I/S St. Michael MN
« Reply #4 on: August 15, 2017, 07:07:07 AM »
If the tank is not completely full, just set it on the front end on a towel or blanket and pull the petcock.  I've done it that way a couple of times with out emptying it.
« Reply #5 on: August 15, 2017, 07:27:35 AM »
There's various channels and vents in the tank. I've set the tank on its end
a couple of times and a siphon effect turned my tank into a gasoline sprinkler.
However, when you set the tank back down flat hold your finger over the vent tube or gas will begin to siphon out. (Makes a neat looking fountain!)
   http://www.valkyrieriders.com/shoptalk/petcock.htm
-Mike "outside is good for this..."
