February 13, 2026, 02:06:46 PM *
Author Topic: Best place to tie in for key on "switched" power on Tourer  (Read 1206 times)
Strider
Broussard, Louisiana
« on: August 21, 2017, 08:10:21 PM »
I know when I did it on my IS, I found an article here that led me to something behind right side cover.  I am not having any luck finding the article again.  I want to put a relay to a fused block and need the key on power to flip the relay.   On a tourer where is the best place to tie into?
Done this relay to both my IS and VStrom but can not remember where I tied into the IS for the switched power.  Seemed like there was a switched wire not used or something under right side cover.
« Last Edit: August 21, 2017, 08:21:22 PM by Strider » Logged
« Reply #1 on: August 21, 2017, 08:21:03 PM »
Strider ! You're back ! It's under the right cover. On mine it was tucked up in the top left corner kind of hard to find. If I remember 2 wires under one of those clearish rubber covers. I don't remember the wire colors.  Undecided A lot of the pics got toasted with photo buckets deal. I'll see if I can find something.
Edit: top right, not left.
« Last Edit: August 21, 2017, 08:27:50 PM by meathead » Logged
« Reply #2 on: August 21, 2017, 08:22:29 PM »
Correct, you just got to rummage around to find it. Smiley
« Reply #3 on: August 21, 2017, 08:26:36 PM »
I think this was just brought up in another post tonight.
Light Green/Red is the power wire , green is the ground.
Strider
« Reply #4 on: August 21, 2017, 08:40:17 PM »
Thank ya'll very, very much.  Can get the stuff on order and get everything wired up when I get a day off again!  Thanks a million!  Ya'll are awesome. cooldude cooldude
Fazer
« Reply #5 on: August 22, 2017, 07:29:49 AM »
There's room for a fuse panel and a relay under the cover.  I also have relay for my Big BF Quad horns behind the battery.  I run all my accessories (except horn) to the fuse panel that is on/off with the key.  Last Sunday, guys I rode with, were talking about the shop wiring up an accessory plug that will run with the bike off.  Recipe for a dead battery if you ask me.
Nothing in moderation...
