February 13, 2026, 02:06:38 PM *
Author Topic: clutch  (Read 1072 times)
swabby420
"Never get out of the boat..."
Oceanside, CA
« on: September 02, 2017, 03:54:31 PM »
Hearing chatter as I shift into 4th and 5th gear. I also hear it when I pull in the clutch and coast...what am I hearing? Got 33k and the first time I've heard this...
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #1 on: September 02, 2017, 04:19:45 PM »
Could be clutch.
First check that the clutch res. Is clean.  Have you changed fluid recently?  If that doesnt clear it up i would next look at the clutch slave cylinder to make sure it isnt causing an issue.
What year, and model?
Where are you located ? As there may be someone who has worked in these issues close to you.  Update location on your profile.
Generally the clutch will slip when accelerating in 4th and 5th.  Most often in 97
i have replaced my clutch.
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
Hooter
S.W. Michigan
« Reply #2 on: September 02, 2017, 04:56:49 PM »
Bleed it and see what shakes out.  What RPMS you shifting at for 4th and 5th? Don't use shift points in the manual,  they are too low. Does the bike do it when it not up to temp?
« Reply #3 on: September 02, 2017, 05:09:24 PM »
If you're shifting to those gears at a low speed, it could simply be driveline slop coming from worn dampers in the rear wheel. It becomes more noticeable at low speed/high gear.
DeathWishBikerDude
« Reply #4 on: September 02, 2017, 10:24:28 PM »
Check the rear gear oil.Rear tire have any service at all?I doubt clutch trouble at 30k.
« Reply #5 on: September 03, 2017, 04:06:27 AM »
Do you feel it in the shifter when changing gears?
Most likely, you have a drivetrain issue.
You're going to have to inspect it starting at one end or the other. Undecided
I'd do as John says and check out the rear drive dampers first.
I lost my clutch (PLATE B, CLUTCH 22322-MZ0-000 $50.29) plate at around 36K.  That was 80K ago.  Never had any issue with a pumpkin.
swabby420
Oceanside, CA
« Reply #6 on: September 03, 2017, 06:50:39 AM »
I have a '98 Standard...I have not changed the fluid since I bought the bike. I really appreciate all the good info.
