February 13, 2026, 07:24:14 PM *
Author Topic: clutch lever ?  (Read 2103 times)
Large
« on: September 08, 2017, 06:46:09 PM »
I have a 1999 IS with 13,000 miles the clutch does not engage till the last 1/2"-1/4" when releasing the lever is this normal? I have changed the fluid and bleed the system but no change.  My other bike is a 2010 triumph thunderbird and it has a manual clutch.
« Reply #1 on: September 08, 2017, 07:26:45 PM »
Normal  cooldude check the little brass bushing in the lever for wear. They get tore up and deformed.
Tfrank59
'98 Tourer
Western Washington
« Reply #2 on: September 08, 2017, 07:31:39 PM »
IMO with that few miles it's probably not the clutch itself worn.  seems like still something with the hydraulics, or maybe the lever bushing?
-Tom
Hooter
S.W. Michigan
« Reply #3 on: September 09, 2017, 05:17:37 AM »
That's what mine does. After market levers can change the feel as well. You can bleed it and see of it changes but it may not? 13,000 miles there should be no issues.  Are you the original owner?  This bike isn't even broke in yet and there shouldn't be a clutch issue unless it was abused.
Large
« Reply #4 on: September 09, 2017, 05:41:57 AM »
The bushing feels good but the levers are chrome not sure if the are stock ?
« Reply #5 on: September 09, 2017, 05:51:01 AM »
If they are chrome, they are aftermarket. Your clutch is normal. The bushing that pushes on the pin is the one you need to examine. With your low mileage it's probably fine.
Edit, I just remembered some of the GoldWing levers guys added were chrome. But they are not stock to the Valkyrie .
« Last Edit: September 09, 2017, 06:11:21 PM by meathead » Logged
DK
Little Rock
« Reply #6 on: September 09, 2017, 02:49:56 PM »
The clutch can be hard to bleed completely.
Try zip tying the clutch to the handlebar for a couple of days & then tapping on the banjo nut at the master cylinder before removing the zip tie.
This has worked for me.
Large
« Reply #7 on: September 10, 2017, 01:15:24 PM »
I got it this spring from my dad he let it set for two years. I have run seafoam and B-12 through it. It has helped the carbs but I plan on doing a carb rebuild this winter along with valve adjustment and timing belts just for peace of mind. And hope to do a speaker upgrade and add rear speakers to make my kids happy. This is a fun to ride bike my other bike is a 2010 1700 triumph thunderbird as has not been riddenmuch since I got the Interstate
« Reply #8 on: September 10, 2017, 02:57:02 PM »
I am always surprised that people are so quick in rebuilding their 6 carbs, because of rough running after extended storage. Rather than just ridding it with fresh fuel and using a good carb cleaner.
I know there is a time and place to get into the carbs, but just using the bike as it was meant to be, is a whole lot easier and more enjoyable. It is amazing how many times people who have stuttering issues, use a stronger than normal dose of cleaner, multiple times, and/or different brands, and then report that after a few tanks of gas, how much better it runs. Most no longer go to Seafoam as a method of fixing this issue, not strong enough.
I used Seafoam and now Stabil Marine for storage. Then on my first new tank of gas, 1/2 can of B12.
Ken Tarver
North Mississippi
« Reply #9 on: September 10, 2017, 05:23:59 PM »
Kuryakyn adjustable chrome levers for gold wing GL1800 will fix your clutch engagement. Cut off the stem that prevents install....then it will fit....I have these on 3 valks. Easy to cut with just a hacksaw. Works perfect.
Also as others stated about fluid.
EDIT: Uh oh, a few sites I checked say not available. Perhaps they were replaced by the Kury boss blades adjustable levers.
Ken
« Last Edit: September 10, 2017, 08:25:13 PM by Ken Tarver » Logged
Dr K
Southern michigan
« Reply #10 on: September 18, 2017, 05:10:45 PM »
Could be the bleed port is plugged in the master cylinder.  Does it get worse the longer u ride? the hotter the bike gets? Does the clutch start to slip?
PharmBoy
Lawton, Ok
« Reply #11 on: September 22, 2017, 12:28:58 PM »
If you have the OEM clutch lever slip it on and try it.  I once had an aftermarket lever that would not let the clutch engage because it didn't have the same angle as the OEM lever.  A careful comparison and a few minutes with a file fixed the problem...Jim
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
Daniel Meyer
The State of confusion.
« Reply #12 on: September 22, 2017, 02:38:26 PM »
Normal...both my Valks engage this way...always have.
CUAgain,
Daniel Meyer
Dr K
Southern michigan
« Reply #13 on: September 26, 2017, 02:36:56 AM »
Not so sure this is "normal" my first three don't do this the one I just bought did act like that so I fixed it now all four are the same see previous post
Dr K
Southern michigan
« Reply #14 on: October 18, 2017, 11:37:55 PM »
Did you ever get this fixed?    Always nice to know the outcome
Large
« Reply #15 on: October 22, 2017, 06:42:24 AM »
I have been to busy with work hope to get new levers be for winter
« Reply #16 on: October 22, 2017, 07:55:19 AM »
skip timing belt should last 100K, not just 13K as on your new to you Valkyrie.
