August 24, 2025, 09:32:36 AM *
Author Topic: Brake fluid and unpainted ABS plastic don't mix  (Read 1043 times)
« on: October 01, 2017, 09:51:47 AM »
I read this post on goldwingdoc
http://goldwingdocs.com/forum/viewtopic.php?f=16&t=38884
Seems a member had a opened bottle of brake fluid in their trunk to top up their reservoir, and it leaks a little. Since the inside of the trunk is unpainted, he notice a problem. The trunk started braking apart.
Not much to read in the above post, just the original post and a reply.
I never knew there was an issue with this, only with brake fluid on painted surfaces.
It's not that I need to carry fluid with me, but I have taken it to our annual maintenance day, and come home with an open bottle in my bag. Something I don't think I'll do any more, but put it in a zip lock bag.
« Last Edit: October 01, 2017, 04:44:54 PM by gordonv » Logged
« Reply #1 on: October 01, 2017, 10:44:34 AM »
I wouldn't trust a zip lock. put it in a larger screw top container, tape both caps and then zip lock.
Hooter
S.W. Michigan
« Reply #2 on: October 01, 2017, 03:43:12 PM »
Some people use it like WD40 to break nuts and bolts loose. My brother in law  swears by it. Would have to watch where you spray it. Never tried it. Brake fluid is not good for anything you like the looks of.
spongebob
Alabama
« Reply #3 on: October 01, 2017, 05:49:53 PM »
Old Military guy worked at the local Ford dealer.
He was a dang good tech.
One day I was there about getting some work done on our older Bronco.
He was working on a truck trying to get water pump off, he got this squirt bottle and put the stuff on the bolt threads.
I asked Alton, what was in the bottle.... He said used motor oil and brake fluid...
He said there aint nothing that it will not loosen OR get rust ,paint out of the way...
Yep.... I got my own little bottle of used oil and brake fluid.... Alton was right....
mello dude
Dayton Ohio
« Reply #4 on: October 01, 2017, 06:19:24 PM »
Brake fluid will also eat paint in a hurry.
« Reply #5 on: October 01, 2017, 06:56:01 PM »
acetone and dextron/mercron automatic transmission fluid or acetone and vegetable oil has been tested and rated best for rusty bolts.
https://www.engineeringforchange.org/how-to-make-penetrating-oil/
« Last Edit: October 01, 2017, 07:02:00 PM by Vaquero (aka 98valk & CA) » Logged
