February 13, 2026, 07:25:50 PM *
Author Topic: CB Antenna  (Read 1076 times)
F6bjorn
« on: October 08, 2017, 07:36:23 AM »
 Smiley Looking for a CB antenna for my Interstate  (08E96-MBY-100)
Bagger John - #3785
« Reply #1 on: October 09, 2017, 06:42:45 AM »
Any GL1200 CB whip antenna will work. The coax lead, connector and mounting stud is also the same between these applications.
A GL1200 antenna mounting arm can be modified to work with the I/S. Search the Tech Board and the Tech Archives - should be some info on the subject around here.
Here's a link to an example part. Sierra and a number of others have these as well. eBay's yer buddy for used ones:
http://wingstuff.com/products/3646-cb-type-3-radio-antenna-for-gl1100-gl1200?context=add_on-cb_radios-gl1200
« Reply #2 on: October 09, 2017, 10:23:00 AM »
Antenna is not the problem, it's the mount.
What do you have, an IS or ?
Now that I own a GL1200 mount, and have a Valk CB ant, I will remove my radio antenna from it's mount, and place the CB one there instead, on the right side. I was a waist trying to figure out a mount for it.
Then buy an inexpensive AM/FM wire radio antenna, and hide it in my IS fairing ($7)
« Last Edit: October 09, 2017, 10:35:44 AM by gordonv » Logged
Bagger John - #3785
« Reply #3 on: October 09, 2017, 10:42:55 AM »
You can also use an AM-FM/CB splitter and the GL1200 CB antenna. Honda offered one as part of their Type II (GL1100) radio setup, and Sierra offers them as new products.
« Reply #4 on: October 09, 2017, 11:12:19 AM »
I had a CB/FM splitter on my bike, and the FM reception was terrible.  Never had a CB (just the antenna).
Bagger John - #3785
« Reply #5 on: October 10, 2017, 05:21:51 AM »
Therein lies the problem - both ports need to be terminated in their characteristic impedance (50 ohms) or you'll experience severe signal attenuation.
« Reply #6 on: October 10, 2017, 08:39:35 AM »
If you're simply looking to buy the part you indicate, post a wanted ad on our classifieds board; that's what it's for.
