February 13, 2026, 07:24:14 PM *
Author Topic: Front tire balancing beads.  (Read 1255 times)
VMODON
« on: October 12, 2017, 03:16:59 PM »
I incorrectly had tire shop put 3oz dyna beads in front tire. I realized my mistake and asked to have them replace with correct 2oz. They said their info showed 3 would be ok for that size tire. I seem to have a bit of a hop at slow to mid speed but smooth at higher speed.
Cracker Jack
« Reply #1 on: October 12, 2017, 04:18:10 PM »
I don't believe there's such a thing as too much unless it's way too much. I don't know how much is "way too much" , or if a bunch is "way too much". Three ounces is not "way too much", in any MC tire.
You will have a problem if you have too little. You only need enough to provide balance, more out of balance, more beads needed. Any over what's needed will simply be distributed around the tire. The recommended amount is somebody's guess as to how much is required to cover a reasonable amount of imbalance. It's not rocket science. cooldude
sixlow
St. Augustine, Fl.
« Reply #2 on: October 12, 2017, 05:10:30 PM »
The hop could be either an out of round tire, or did they leave the rim weights on ?
« Reply #3 on: October 12, 2017, 05:51:06 PM »
I have only heard of people using more in the rear tire than what was required/recommended (4 oz), but have never heard of an issue when this was done.
VMODON
« Reply #4 on: October 12, 2017, 06:40:19 PM »
Thanks for your thoughts. wheel had beads in it prior to this tire. Usually with a new tire front end is nice and smooth until the tire starts wearing down. this time was not the case.
Steel cowboy
Spring Hill, Fl.
« Reply #5 on: October 12, 2017, 07:58:49 PM »
I have 4 oz in each tire on my interstate. I have them in my pick up truck too. You can not over do it, never had a problem, they are both smooth running all the time.
2001 black interstate
2003 Jupiter Orange wing
mrtlc
Elroy WI
« Reply #6 on: October 13, 2017, 05:49:41 AM »
Try putting the bike on a jack until the tire is off the ground. Then place a block in front of the wheel and rotate the wheel to see if its out of round. You can also do this to the side.
99 Interstate 1500
89 Goldwing sidecar 1500
88 Goldwing 1500
85 Goldwing 1200
84 Gold wing 1200
80 Goldwing 1100
79 Yamaha XT500
78 Honda 750K
