August 24, 2025, 02:21:58 AM
Carburetors leaking gas
Topic: Carburetors leaking gas (Read 1089 times)
spartacus1215
October 30, 2017, 07:36:05 PM »
Help!! My '98 STD is leaking a lot of gas through the carbs. This started after the hurricane Irma hit us here in Key West. The bike did not go under water at all; it was on a raised platform and was safe. The leak started after I replaced the pulse coils and all 3 ignition could due to a no spark issue. Runs fine now except for the massive gas leak. So far I have rebuilt all the carbs and reassembled. The leak is exactly unchanged. All the hoses are fine, the vacuum lines are fine, and I put in a new petcock. The tank is fine. Where else should I be looking?
Harryc
Sebastian, Fl
Re: Carburetors leaking gas
October 30, 2017, 07:38:26 PM »
Where exactly is it leaking from?
http://s724.photobucket.com/user/Harryc56/slideshow/Valkyrie
October 30, 2017, 08:04:04 PM »
Sounds like fuel rail O-rings
longrider
Vernon, B.C. Canada
October 30, 2017, 08:21:12 PM »
Start the bike up again tomorrow and let us know how fast it is leak and from where
1NorthRyder
Elliot Lake, Ontario, Canada
October 31, 2017, 08:06:45 AM »
Earlier this year I was prepping for a trip and started the Valk and fuel was pouring out the front of the bike from the carbs. It happened two or three times over one week. I believe it was the fact that the choke cable stuck wide open. I got it loose and haven't had an issue since.
spartacus1215
October 31, 2017, 12:29:18 PM »
Hey guys, thanks for your help. Leak is around carbs 3 and 5. I think it's the fuel rail O-Ring issue one reader mentioned. I ordered the Red Eye kit and will be taking it all apart again. Bumming!!!!!!!
Reply #6 on:
October 31, 2017, 01:38:14 PM »
A good guess and the right solution.
Reply #7 on:
October 31, 2017, 08:01:07 PM »
Quote from: Willow on October 31, 2017, 01:38:14 PM
It was an easy guess. Good had nothing to do with it.
=> InZane XXV
