March 15, 2026, 05:33:43 PM *
Author Topic: Did a couple of Jack Mods  (Read 1823 times)
pocket aces
Tampa, Fl
« on: November 03, 2017, 12:52:59 PM »
Yep, did a couple of Flrider mods. They both can be seen in the first pic. Can you name them both?
Well I put all the goodies back on her just the way I bought her. I do like the change and the look. Upgraded my speakers all the way around with the Polks DB 501's. Love the sound. Still on the fence about adding an amp. Added a Stebil compact horn under the swingarm and a couple aux outlets.
Starter took a crap on me.  Cry Hopefully thats all it is. I should be up and running for the Pizza Party.. cooldude
Thunderbolt
Worthington Springs FL.
« Reply #1 on: November 03, 2017, 02:21:33 PM »
I have only heard of one actual starter problem in 15 or so years.  Usually it is either the starter button contacts or the wiring underneath the right side cover at the main fuse/relay.
« Reply #2 on: November 03, 2017, 02:57:52 PM »
+1, these starters, like the motor, are pretty much bullet proof. You need to do some checking before you pull the starter....that's not a piece of cake. Is it possible you have a hydrolock? Pull the plugs and see if the engine will turn over, if so....hydrolock.
Flrider
Jack
Kissimmee FL
« Reply #3 on: November 03, 2017, 05:58:21 PM »
Looking good there Vance, now get that Gremlin worked out of the phat lady so you can make the Pizza Party and we can check out the new additions  cooldude cooldude
Grumpy
Tampa, Fl
« Reply #4 on: November 03, 2017, 07:09:29 PM »
His starter has been real noisy for a while, hoping the reduction gears in the starter have gone. But will find out when I pull it off, hoping non of the gears in the motor are bad.
Bert AKA,Valkaholic
Back-N-Black
« Reply #5 on: November 04, 2017, 10:50:02 AM »
I Have A Parts Starter  If Needed !  The Lead Band That Connects To Two Of The Brushes Is Burnt, The Rest Looks Good.
Grumpy
Tampa, Fl
« Reply #6 on: November 04, 2017, 12:18:14 PM »
I have a few complete ones
sixlow
St. Augustine, Fl.
« Reply #7 on: November 04, 2017, 05:24:21 PM »
The sleek shield and the driving lights ??  Cool      Did I win ?    Undecided
pocket aces
Tampa, Fl
« Reply #8 on: November 04, 2017, 06:23:12 PM »
The sleek shield is one. I love the look of it and height. 11.5". I got mine off Amazon for $55.00. Thanks to Jack for the great write up with pics.  cooldude
pocket aces
Tampa, Fl
« Reply #9 on: November 06, 2017, 07:39:45 AM »
I also added a pair of Rivco turn signal mirrors. Really liked Jacks alot!!  cooldude They have red LED's blinkers on the mirror side and yellow run/turn on the front side.
larue
Clermont,FL
« Reply #10 on: November 06, 2017, 01:30:01 PM »
You follow jacks path you'll be broke quick  uglystupid2 uglystupid2
