November 15, 2025, 03:49:32 AM
Alternator remove and replace
Topic: Alternator remove and replace (Read 1302 times)
Lyle Laun
Calgary, Ab
November 09, 2017, 06:17:38 PM »
Just want to give a shout out to everyone on this board. I replaced the alternator on my standard the other night and if it wasn't for the info gained from this board, I would have believed that it couldn't be done without pulling the motor !
It was a struggle (2hrs to remove) and about 5 minutes to put the new one in - go figure. I also took John Schmidt's advise and used a touch of silicone to hold the upper rubber blocks in place on the install.
Thanks Again
Lyle...
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
Re: Alternator remove and replace
November 09, 2017, 09:08:09 PM »
2 hrs to remove? Wow, Ive heard of 2 days (and longer), but not much problems for pulling.
To put it back in, do you recollect in what position the X was in (horizontal/vertical or just somewhere?)
Bone
November 10, 2017, 01:31:33 AM »
My first time was similar. gordonv your idea is the solution to easy installation. I couldn't believe the alternator was ever in the place I was trying to install it until I thought about the tilting and turning that removed it. It falls into place if you can reverse the removal motions.
Lyle Laun
Calgary, Ab
November 13, 2017, 08:08:38 PM »
Gordon:
As soon as it finally in position to come out, I just stopped and had a good look at the angle it was at and remembered it for the install.
Lyle
Get out & Ride !!
November 14, 2017, 08:37:54 AM »
Quote from: Lyle Laun on November 13, 2017, 08:08:38 PM
Gordon:
Lyle
Sooooooooooo didja learn new cuss words?
Gits a bit easier after the 2nd time.
RIDE SAFE.
=> InZane XXV
