July 11, 2025, 05:41:12 PM
Sparkplug gap?
Topic: Sparkplug gap? (Read 4184 times)
Mr.BubblesVRCCDS0008
Sparkplug gap?
October 26, 2009, 06:22:00 PM »
I'm doing some long overdue maint. and my manual is not here at the house. What is the gap set at.
F6Dave
.31 - .35
October 26, 2009, 06:30:13 PM »
I've found the NGKs to be in that range out of the box.
Re: Sparkplug gap?
October 26, 2009, 06:40:10 PM »
I found the gap in shop talk to be 31 to 35 thousands. I started out to change the timing belts this morning and found all my intakes leaking at the o rings.The kury covers had kept all this hidden. So I got new orings this afternoon. Then I decided to to (check) or adjust the valves while I had the bike on the jack.This lady has 111k on her and I thought I'ld better spend some quality time and money on her to make her feel special. It always seem to work on the wife.
John U.
Southern Delaware
Re: Sparkplug gap?
October 26, 2009, 07:27:07 PM »
Mr. Bubbles, if your wife is computer literate you are in deep.
Now, regarding spark plug gap, if you run irridium plugs you can open the gap to .36 to .38 without a problem. I found that .40 is a bit too much. I think I felt a miss at high speed or WOT.
Farther
Quimper Peninsula, WA
Re: Sparkplug gap?
October 26, 2009, 09:12:36 PM »
My shop manual says between .8-.9mm.
~Farther
1fastbob
South Central Kansas
Re: Sparkplug gap?
October 27, 2009, 03:56:24 AM »
.035"
I'm on somebody's list! BFD!
=> InZane XXV
