November 15, 2025, 03:36:01 AM *
Author Topic: Dark side  (Read 1301 times)
muscrat
My Shrink
Tilbury On, Southern most area of Canada
« on: December 12, 2017, 06:10:19 PM »
Well after listening and reading all the comments, suggestions and preferences re CT I ordered my first one. Went with the Champiro 205/60/16 which should be in Tuesday. I went with that size since I read here it was the closest is size to the stock MT. My only question now is, I ride 2 up 95% of the time with a full Saddleman bag on trips, what would the recommended air pressure be and will the mod on the fender nut removal be the only requirement. Have stock I/S shocks that are fairly new on my 97 Standard. Any other suggestions appreciated.
Muscrat (c'mon Spring)
So Many Roads, So Little Time !
da prez
Wilmot Wi
« Reply #1 on: December 12, 2017, 07:00:10 PM »
You pretty much have it. Nut cage mod is advisable. You could install the tire and leave shocks off to check clearance by jacking the tire up to see if it clears the cage. If you have room.  You are good to go. Cage mod could still be done . Follow torque  and install procedures.
                               da prez
« Reply #2 on: December 12, 2017, 07:06:10 PM »
Try starting at 38 psi for 2 up.I'm a big bulky bastard and 34 psi seems to have worked for my Champiro. I started at 42 psi for the first couple of thousand miles but that took too much tread off the center of the tire.
da prez
Wilmot Wi
« Reply #3 on: December 12, 2017, 07:08:36 PM »
Also , put a block of some kind under the front tire. jic
                     da prez
« Reply #4 on: December 13, 2017, 05:16:44 AM »
                     da prez
OR
Both sides of the bike
« Reply #5 on: December 13, 2017, 05:19:19 AM »
Put a strap over the bike as well. Remove side panels and seat.
CAUTION.
Remove side panels carefully. Pull outwards from the rear. Gently! There's 2 grommets to pop off.
Then slide out from front tab. Gently!
Be equally gentle when putting them back on.  cooldude
Fazer
« Reply #6 on: December 13, 2017, 05:20:00 AM »
Who needs jack stands??????  Nice work around Britman. Grin
Nothing in moderation...
0leman
Klamath Falls, Or
« Reply #7 on: December 13, 2017, 07:45:09 AM »
I still use jack stands as don't have enough paint cans sitting around nor scrap lumber.   2funny 2funny
« Reply #8 on: December 13, 2017, 02:04:05 PM »
                     da prez
OR
Hey, the can says right on it "Multi-Purpose" cooldude
Is the Sherman-Williams?  They have the best cans for stacking Roll Eyes
« Reply #9 on: December 13, 2017, 05:46:10 PM »
                     da prez
OR
muscrat
My Shrink
« Reply #10 on: December 13, 2017, 06:09:19 PM »
Many thanks for all the feedback as well as the humor, not enough of it in the world today.
muscrat.
