April 30, 2026, 07:01:47 AM *
Author Topic: Robert-michelin question  (Read 4578 times)
Adirondack Bill
Upstate New York Near Lake George
« on: December 14, 2017, 07:30:02 AM »
Robert, you recommend the Michelin Road 4 Trail  120/70r19 for the front. Our manual calls for a wider tire- (130). Is it ok to use a narrower tire? I have used wider tires in the past but not narrower. Is there much difference going from a 130 to a 120?
PAVALKER
Pittsburgh, Pa
« Reply #1 on: December 14, 2017, 01:38:32 PM »
Its fine....  I have a 120 Avon on the front of mine, it's all good.
John
« Reply #2 on: December 14, 2017, 02:59:21 PM »
No problem at all for mine and quite a few others. What you may notice is a little quicker steering response but that is about it. Keep the pressure to 39 to 41 and you wont have a problem with cupping and its pretty critical that you keep it in that range. You can go lower but it may cup.
  When I picked these tires there wasn't to much selection and nothing in our size. But now there are a few in our size and you could check those out also. I am going to stay with the Micheline since I have had no problems and like the tires and trust the name. If someone says they have a great tire I may try it but really I have a set always waiting in the wing and with 24k miles on the bike with these tires I really dont see the need to change. Wet they are great, dry great just a nice tire all the way around.
Just as kind of a side note, and one thing I always also liked about these tires is they were made for a bit of off road. I have upon occasion come across a dirt road and always felt a bit more confident knowing I had a tire that was made for that kind of thing.
« Last Edit: December 14, 2017, 03:23:57 PM by Robert » Logged
pago cruiser
Tucson - Its a dry heat
« Reply #3 on: December 14, 2017, 05:02:48 PM »
Was there any significant difference in overall diameter on the front or the rear?
« Reply #4 on: December 14, 2017, 06:00:14 PM »
This should give the exact information for the front. The rear is oem size so the difference should be minimal.
https://www.tacomaworld.com/tirecalc?tires=130-60r19-120-70r19
wtm
Welch Village Ski Area, Minnesota
« Reply #5 on: December 15, 2017, 04:31:53 AM »
I think I will gave them a try next change.
Freedom, never let them take it away.
st2sam
N.E. Pennsylvania
« Reply #6 on: December 15, 2017, 05:39:14 AM »
No problem at all for mine and quite a few others. What you may notice is a little quicker steering response but that is about it. Keep the pressure to 39 to 41 and you won't have a problem with cupping and it's pretty critical that you keep it in that range. You can go lower but it may cup.
Robert you hit the "nail on the head".
I run 42psi cold front & rear.
 I'm on my third set.
Try'em you'll like'em.  cooldude
ledany
Paris, FRANCE
« Reply #7 on: December 15, 2017, 12:57:19 PM »
36 psi front/42 psi rear, never more !
I changed my Pirelli Scorpion Trail II recently (front), 12,500 miles on it for another Trail II.  cooldude
Adirondack Bill
« Reply #8 on: December 15, 2017, 04:55:29 PM »
Thanks Robert,  I will be due for tires in the spring. Will give these Michelins a try.
« Reply #9 on: December 16, 2017, 04:39:27 AM »
Revzilla did a review that is pretty good just for some more information.
https://www.revzilla.com/motorcycle/michelin-pilot-road-4-gt-tires
« Reply #10 on: January 01, 2018, 04:35:00 PM »
Since photostash went down I was not able to show a pic to this so now that I set up another site I can finally post a pic
