November 15, 2025, 01:38:09 AM *
Author Topic: diagrams and fuse box  (Read 1198 times)
kc5tf
« on: December 14, 2017, 06:25:56 PM »
where can I get a work manual and is the fuse box on the left or right before I start ripping of parts.tnxs for your patience
WintrSol
Florissant, MO
« Reply #1 on: December 14, 2017, 08:21:11 PM »
You can download a manual here: http://valkyrienorway.com/download.html
indybobm
Franklin, Indiana VRCC # 5258
« Reply #2 on: December 15, 2017, 06:12:16 AM »
+1. The fuse panel is on the right side.
So many roads, so little time
VRCC # 5258
« Reply #3 on: December 15, 2017, 07:22:38 AM »
Speaking of "ripping of parts," be very careful removing side covers, as the connection at the front of the side cover, where it connects with the centre cover, is very fragile; don't force it to release or you'll hear a "snap!"
« Reply #4 on: December 15, 2017, 10:25:11 AM »
http://www.rattlebars.com/valkfaq/schematics/index.html
« Reply #5 on: December 15, 2017, 08:47:48 PM »
Gryphon Rider is right, you need to remove it from the back end first and kinda swing it out a little before removing the front tab. Reason for that is because that tab has a slight hook to it and when you try to pull it straight out, that's when you get that "snap." It breaks! If you swing the back end out first it causes that "hook" to move out of the latching position before pulling it out.  cooldude
