May 09, 2026, 03:08:10 AM *
Author Topic: I got ambitious this weekend.  (Read 3769 times)
BigMac (SoCal)
Moreno Valley, California
« on: January 22, 2018, 11:31:49 AM »
Well I decided to take a look at my Valk records the other day and determined that it had been a while since I serviced my bike. Last year I changed the needle jets in the carbs to make the bike run a little richer. Although it ran ok the bike always seemed to smell like raw gas. So I changed them back to the stock jets. Not a hard job at all. Then I synchronized the carbs which were not far off at all. Changed the plugs which look great. Then I adjusted the valves which only a few were a little loose. After buttoning it up took it for a ride and found my left valve cover was leaking. Tried to reinstall and it still leaked. We considering it's 19 years old I replaced it with a new one and all is good to go. Next I plan on replacing my almost 4 year old battery and front tire to get ready to InZane this year. Last month I also replaced my timing belts, pulleys and springs. Amazing bike for sure. 163000 miles and it does not burn any oil. cooldude
Ride safe everyone,
Dave
« Reply #1 on: January 22, 2018, 04:37:53 PM »
 cooldude I think I'm going to replace my belts and pulleys before Inzane.
Gary
Northern New Mexico
« Reply #2 on: January 31, 2018, 06:54:32 AM »
I think I'd like Dave to do all that to my 97 too please!  angel
« Reply #3 on: January 31, 2018, 08:18:32 AM »
2funny
BIG Bopper
Rolling Thunder 2017
Palm Springs, CA
« Reply #4 on: February 21, 2018, 03:48:57 PM »
Having a vacuum or carb issue. How much time should I alot to clean and rebuild the carbs?
Tim "Big Bopper" Bannister
Owner
Celebrity Tours
Palm Springs, CA
BigMac (SoCal)
« Reply #5 on: February 22, 2018, 08:05:31 AM »
I've done a few carb jobs. But I would give yourself a couple of days at least. Take your time and you should be fine.
Dave
RichW
Apple Valley, California
« Reply #6 on: February 22, 2018, 04:42:11 PM »
Here is a series of videos on how to do the carbs. I have never done this myself, just bookmarked.
https://www.bing.com/search?q=rebuilding+a+carburetor+on+a+honda+valkyrie&qs=n&form=QBRE&sp=-1&pq=rebuilding+a+carburetor+on+a+honda+valkyrie&sc=0-43&sk=&cvid=B1C971D7807D4CD4BD8101677E4E5938
1999 Black Valkyrie
« Reply #7 on: February 22, 2018, 04:55:08 PM »
Dave
Dave is right. It can be done in one day if you have done it before and keep after it. But 2 days is much better. I would recommend replacing the fuel rail o-rings while you have them out. Take pictures of throttle cable and choke cable routing before you take apart. The jets have some tiny holes that get clogged. I found it helpful to unstrand some wire and use one strand of it to help clean these.
