February 14, 2026, 01:06:39 AM
Need carb stay plate spring
Topic: Need carb stay plate spring (Read 1209 times)
longrangelarry
January 23, 2018, 06:51:50 PM »
Need help finding or making a carb stay plate torsion spring for my 98 tourer. It popped off and disappeared in the garage during work. Still looking for it, but meanwhile I tried to buy one. It is part 5 on the carb parts diagram. Appears to be unavailable and I couldn't find an old one either. I assume I can bend a suitable spring to work but I have no idea how hot to heat it without ruining it. Any help appreciated!
Harryc
Sebastian, Fl
Re: Need carb stay plate spring
January 24, 2018, 02:25:40 AM »
https://www.amazon.com/Honda-HONDA-16050-MZ0-000-SPRING/dp/B00NO0FD9Q
http://s724.photobucket.com/user/Harryc56/slideshow/Valkyrie
longrangelarry
January 29, 2018, 08:31:51 PM »
Thanks but that is not the right spring. I need #5 on the carb assembly diagram. However, if you happen to know they are the same as 6 & 7 by all means let me know. I believe 6&7 are heavier but I will definitely look. But I sure am not going to take one off!
Harryc
Sebastian, Fl
January 30, 2018, 02:54:46 AM »
Yeah Ok, you need part number 16051-MZ0-000. If you google search it you'll see a couple of parts houses in Europe that 'might' have it, but I couldn't find it anywhere else. That could be pricey if they have it at all. I'd be tearing my shop a apart to find it ...
Attic Rat
VRCC # 1962
Tulsa, OK
January 30, 2018, 10:07:35 AM »
ok larry call me and i'll get you one 918-720-5444
