February 14, 2026, 01:05:29 AM
Rattlebars heal toe shifter maintenance
Topic: Rattlebars heal toe shifter maintenance (Read 1188 times)
ValkISDan
Forest Lake, MN
February 02, 2018, 05:18:16 PM »
I'm going to remove my Rattlebars shifter for some long needed maintenance. I found one thread where someone installed some bearings inside, does anyone have any good ideas for rebuilding this or specs for new O-rings?
97BLKVALK
VRCC#26021
Detroit Lakes, MN
Re: Rattlebars heal toe shifter maintenance
February 03, 2018, 01:58:35 PM »
Are you referring to rear end maintenance and the o rings including the elusive 3rd o ring. If so here's a link.
http://www.carolinabikeandtrike.com/ORings.htm
Michael
Last Edit: February 03, 2018, 02:07:09 PM by 97BLKVALK
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
February 03, 2018, 05:49:16 PM »
The heel/toe shifter has no maintenance to do. But if you must, just lube the pivotbushing with a heavy waterproof grease and wipe off the excess after every ride till it stops oozing out.
Kunkies
Charlotte, NC
February 04, 2018, 02:52:24 AM »
Yes there is Rattlebars kick-shift maint., albeit very minor.
1. Every oil change add two drops of oil to the pivot point, 3&1 oil works fine, and
2. Use white lithium grease, lightly lubricate the touch-points on the front of the kick-shift where it makes contact with the original front gear shift assembly. I use a q-tip.
ValkISDan
Forest Lake, MN
February 04, 2018, 05:11:29 AM »
It just feels like the unit has more play than before.
Kunkies
Charlotte, NC
February 04, 2018, 07:25:25 AM »
Key word: "Rattle. . . "
