November 14, 2025, 11:19:38 PM
Finally bit the bullet and did it
Topic: Finally bit the bullet and did it (Read 1213 times)
February 12, 2018, 01:43:59 PM »
Been thinking about syncing the carbs on the Cobra bike. Kept talking myself out of it because it runs SO good. But then I asked myself...maybe slow change over time went unnoticed. So I got the Twin Max thinggy out and played with it a bit. It's been a long time since I messed with it. (This bike has never had a sync) So once I had my confidence up I started. Three of six (actually 3 of five) because #3 doesn't adjust. Needed a very minor tweak. I m talking 1/16 to 1/8 ". All needed clockwise adjustment so that's adding "juice" to the mix
I immediately rode up the street and back and there was a small but noticable improvement in "snappiness" off the line. Idle was always real smooth and it still is, maybe even smoother.
Bottom line...glad I did it.
Hooter
S.W. Michigan
Re: Finally bit the bullet and did it
February 12, 2018, 02:45:29 PM »
Never have done mine either. Idles smooth, runs great, no known carb issues. I won't touch it until I have something change.
February 12, 2018, 02:50:27 PM »
Quote from: Hooter on February 12, 2018, 02:45:29 PM
It's easy to do. Mine was similar to Jeff's. Very small adjustments. But I could notice a slight difference in throttle response.
February 12, 2018, 02:53:24 PM »
That was me too, but now I'm glad I did it
mbramley
Painesville Ohio
February 13, 2018, 09:01:00 AM »
I pulled my carbs last year. Cleaned and new seals. I synced with 6 vacuum gauges. I had good results and pretty easy. I put the gauges on a small piece of pegboard so it stood above the forks.
=> InZane XXV
