March 15, 2026, 01:42:29 AM
1800 Tech Board
Bar End Mirrors?
Topic: Bar End Mirrors? (Read 2717 times)
CruiserNewb
Bar End Mirrors?
February 17, 2018, 09:48:32 PM »
I was wondering if it’s possible to put bar end mirrors on the Valkyrie. I saw in the service guide where it talked about an internal weight. I only have experience with sport bikes and coupons that are completely hollow. Do the end caps just pop of on our grips? Any advice greatly appreciated.
Pete
Re: Bar End Mirrors?
February 18, 2018, 04:15:06 AM »
The left side grip cap is a screw in, the right side is one piece(grip and cap). That is is first problem.
As for the weight I have not tried to remove them, so do not know.
bscrive
Ottawa, Ontario
February 18, 2018, 04:53:46 AM »
I took the weights out when I changed my handlebars. I don't notice any difference. I changed my grips to Avon grips and I used their cramp buster, but I could have left the ends clear. I don't know if you could use bar end mirrors with the OEM grips, but if you changed them, then I don't see an issue.
CruiserNewb
February 18, 2018, 06:32:28 PM »
I was wanting to change my grips as well so that would be possible if I just get ones with open ends. Do you like the Avon’s then? Did you end up putting weight back in or no? And you didn’t think it changed any feel or vibration?
CruiserNewb
February 18, 2018, 06:33:45 PM »
Almost forgot, are they 1” bars when I look for new grips?
bscrive
Ottawa, Ontario
February 18, 2018, 07:13:22 PM »
The Avon grips are great and a lot better than the OEM grips.
Yes, our bars are 1".
