February 14, 2026, 03:09:55 AM *
Author Topic: Opinions: Cobra 6:6 Install  (Read 1167 times)
Murrgh
Williamsburg, VA
« on: March 06, 2018, 10:26:54 AM »
Picked up a set of 6:6 pipes and was planning to install soon. I've been reading different posts about what to do after the install and I've seen controversy over rejetting/retuning the carbs vs not. Also, getting a K&N filter vs not.
What are the thoughts on this in 2018?
« Reply #1 on: March 06, 2018, 11:15:01 AM »
With my cobras there was no need for rejet. But it ran better with K&N.  No loss of power or gas mileage.  Just ran too rich with the OEM filter.
Roidfingers
Tuscaloosa, Alabama
« Reply #2 on: March 06, 2018, 03:09:32 PM »
Really? I have cobras and have a K&N, but never installed. So you just oiled yours and put it in? Yes I never rejetted either.  So the K&N allowing more air, took away the richness? But could you not adjust your fuel/air mixture screw to lean it out? Curious, not judging. TIA. BTW no baffles.
« Last Edit: March 06, 2018, 03:14:42 PM by Roidfingers » Logged
« Reply #3 on: March 06, 2018, 03:53:57 PM »
I always ran baffles.  I would have had to get onto the carbs if switching to the K&N didn't work so well
Hooter
S.W. Michigan
« Reply #4 on: March 07, 2018, 03:53:53 AM »
Any bike I've had I've gone by  one rule. Change the exhaust don't worry about re-jetting.  Mess with air side then re-jet. Especially when both are changed from stock. The air change I definitely did. I've never done anything to my valk, its still stock. (Pigs are cut but that has no effect.) That so called rule has never failed yet.
I have a set of 6s in the shed that I took off. Too noisey for my taste.  When I put stock back on, other than a noise reduction nothing really changed with the way the bike ran.
« Last Edit: March 07, 2018, 08:19:04 AM by Hooter » Logged
BoatersPal
« Reply #5 on: March 07, 2018, 06:19:14 PM »
 Sad Anyone know if there is a difference with hp in a 1997 to a 2003 Standard? 2nd question what is the average hp in the Valkyrie? 3rd What will the make the most hp? using what exhaust and Proper Air Filter ? 4th question what is the hp on a Stock 2014-2016 Valkyrie? I am asking because I am either re[lacing my 2008 or buying a used 2014, I have seen them for abbout $8,000 that is a very good deal, from where my thinking is.
