News:
Main Menu
shout out for
Started by old2soon, Mon 18, May 2026, 11:40:45
Previous topic - Next topic
     Dennis kirk. Back on 5/14/26 I ordered a throttle paddle for the 12 GW. When I completed the order it said delvery om 5/20/26. Well that part arrived today intact and very well packaged. And it IS larger than the 1 that is currently on the GW. That smaller paddle wuz causing the right hand and wrist to go numb!  :-X  NOT a good thing fer any RIDER!  :-\  Be gittin that mounted A S A P!  :cooldude:  RIDE SAFE.
Considered getting one for my Wing, I use the one on my Valk quite frequently but with actual cruise control on the 'Wing I just run with that.
I do see the use of a quick way to hold the throttle to pick my nose or something might be helpful without needing to engage the full cruise control...
Quote from: Serk on Mon 18, May 2026, 13:44:12Considered getting one for my Wing, I use the one on my Valk quite frequently but with actual cruise control on the 'Wing I just run with that.
      The paddle the 12 arrived with is sort of a rounded taper shape! I tried adjusting it and no go. I also spent just a bit more and went with the chrome paddle.  :cooldude:  RIDE SAFE.
