Cobra drag pipe carb mods shimming vs rejetting
Started by calcruiser, Fri 22, May 2026, 16:10:45
Previous topic - Next topic
calcruiser
looking for anybody's experience with shimming the needles for a bike with cobra sixes and baffles in.  my gut is telling me this is the way to go to reduce popping and gurgling.  guts telling me leave the jets alone.  happy to do whatever is best though to get it dialed.  probably try shimming first since it's so easy anyway and seems to me like it would solve the problem perfectly, but feedback is highly valued on this site.  it's my first bike with cobra drag pipes.
Quote from: calcruiser on Fri 22, May 2026, 16:10:45looking for anybody's experience with shimming the needles for a bike with cobra sixes and baffles in.  my gut is telling me this is the way to go to reduce popping and gurgling.  guts telling me leave the jets alone.  happy to do whatever is best though to get it dialed.  probably try shimming first since it's so easy anyway and seems to me like it would solve the problem perfectly, but feedback is highly valued on this site.  it's my first bike with cobra drag pipes.
I had Cobra pipes on for many years. Didn't need any carburetor changes whatsoever. Bike ran great!!
when g
when going off throttle all gas engines go lean temporarily thereby the popping.
opening up the idle mixture screws help reduce it, open too much will be too rich and mpg tanks.
there are two types of popping lean is more common and too rich is less common.
calcruiser
[/quote]
[/quote]
thanks for input, glad to hear that.  i'm going to hold off on any carb mods until i'm sure everything is buttoned up tight. i'll do new exhaust gaskets, install air box mod kit from valk carbs and customs, new intake tube 0-rings, new intake boots, and replace vacuum lines with silicon tubing.  if it still pops i'll fool with the mixture screws.  there is no doubt it's too lean right now.
calcruiser
Quote from: 98valk on Fri 22, May 2026, 17:57:08when g
i think this bike wants more gas.  i'm gonna seal it up tight and see what happens.  once sealed up i'm guessing i'm gonna need to adjust out a 1/4 to 1/2 turn on mixture screws.  shimming probably ain't the best approach on a bike with a hydrolock curse.  appreciate your input.
[/quote]
[/quote]
major source of vacuum leaks has been the vacuum caps on the intake manifold carb sync nipples.
silicone tubing doesn't like gasoline and its fumes. best to replace with Buna-n aka nitrile which is what the factory uses, however there are different grades of buna-n. u need to buy the higher grade type. Buna-N doesn't like sunlight so Viton is a better choice for sunlight if u what zero problems for the next 30yrs.
if your intake manifold o-rings were leaking, the idle would be going up and down due to a vacuum leak. tighten the boot clamps, manual requires all fasteners to be checked every 8k miles.
exhaust nuts only take 7 ft/lbs.
unleaded gas does not color the spark plugs porcelain like leaded gas did, so not an indicator of leaness.
http://www.factorypro.com/tech/tech_tuning_procedures/tuning_carbtune,CV,lower_rpm_engines.html
http://www.factorypro.com/tech/tech_tuning_procedures/tuning_pilot%20jet,%20affect%20of%20size%20on%20idle%20and%20cruise.html
calcruiser
thanks 98 tons of valuable info.  didn't know the gas and silicon thing. i checked those caps and look alright, but it's all old stuff.  i'll get the viton tubing.  in my case it was another indicator of leaking intake manifold o-rings, oil pooling on the engine around the tubes.  bikes don't like to sit.  think this one sat for quite awhile.  i know it's a great engine though.  thanks again for your help gettin it right.  i'll rebuild the carbs on it this winter and should be done with it.
Quote from: calcruiser on Sat 23, May 2026, 13:20:33thanks 98 tons of valuable info.  didn't know the gas and silicon thing. i checked those caps and look alright, but it's all old stuff.  i'll get the viton tubing.  in my case it was another indicator of leaking intake manifold o-rings, oil pooling on the engine around the tubes.  bikes don't like to sit.  think this one sat for quite awhile.  i know it's a great engine though.  thanks again for your help gettin it right.  i'll rebuild the carbs on it this winter and should be done with it.
"oil pooling on the engine around the tubes."  that is the gasket hi-tack used on the o-rings to hold them in place on the assembly line melting and seeping out. any time there is a vacuum leak on a intake manifold the engine idle will go up and down and never be steady.  Carb rebuild? OEM o-rings don't go bad unless exposed to chemicals they don't like. pull the bowls and clean the main and pilot jets along with the bowls. bowl gaskets will be fine to reuse.
Quote from: 98valk on Sat 23, May 2026, 15:36:33
Check the screws on the carb tubes.  If they;re not tight tighten them down and clean off the residue around them.  What you see as oil may be bits of fuel leaked and dried.
Quote from: Willow on Sat 23, May 2026, 18:58:47
there isn't any liquid fuel inside of the manifold in that area, it is all an atomized air/fuel mixture at that point. and there isn't an area in there where fuel could puddle and seep out before evaporating from engine heat.
Quote from: 98valk on Sun 24, May 2026, 05:46:25
For however you explain it, several times on different Valkyries I have seen that, tightened and cleaned and it stopped.
calcruiser
think this bike sat for about 3 years.  barely ran when i bought it and i had 3 other bikes to work on so to get it going i used chem tool, worked awesome but think it did damage o-rings in carbs cause now it floats back down to idle.  both valks i bought last year had the oily gassy sticky slime around tubes.  tightening worked on other but not this one.  new o-rings did the trick.  i really want to do the carbs just to do them.  i love these valks and just wanna get in there so i know what's up, like getting to know your best girl.  basically wanna do the carbs for fun.  don't watch t.v. or youtube or listen to radio anymore, done with all that mess.  now i'm looking for anything to do on my bikes.  just about all i do now.  listen to cassette tapes and wrench.  starting a vtx 1800 custom this week.  it's currently that honda illusion blue that looks purple.  for me it's the worst color for a motorcycle i've seen.  can't think of a color i dislike more on bikes.
