News:
Main Menu
The ACC terminal
Started by KTRT, Sat 30, May 2026, 09:56:20
Previous topic - Next topic
KTRT
Hello everyone. Since I'm stuck at home with a broken wrist and way too much time on my...hand, I've been pondering adding a phone holder and something to power it on the 99' standard.
According to the manual, there's a pair of jacks underneath the right side plastic cover (which I found indeed), but I'm struggling a bit to find the correct kind of cables and plug. Anyone got an idea of what I should be looking for? I want to make a clean and discreet installation.
Timbo1
I used 3.5mm bullet connectors to add an Android Auto / Car Play device and they fit fine.
These are the exact ones I used that I had laying around from a previous project but they appear to be unavailable at the moment. 3.5mm bullet connector
Quote from: KTRT on Sat 30, May 2026, 09:56:20Hello everyone. Since I'm stuck at home with a broken wrist and way too much time on my...hand, I've been pondering adding a phone holder and something to power it on the 99' standard.
Standard bullet connectors. Just get the correct size
You should be able to find those connectors at Ace, Lowes or Home Depot. You won't have to buy 100.
KTRT
Quote from: Chrisj CMA on Sat 30, May 2026, 11:28:10
Thank you, I think I have some laying around somewhere.
luftkoph
cycle terminal.com if you want quality electrical parts not Chicom amazon stuff
Honda used 3.5 mm bullet terminals Suzukis and Kawasaki used 3.8mm it makes a difference.
Some day never comes
rug_burn
If you want to make sure you don't have intermittent connection problems, solder the crimp-on connections to the wires, too.   That's the aviation standard.
...insert hip saying here..
ridingron
#7
Scroll down from the first link "3.5mm bullet connector" and you'll find several kits. As mentioned above, get the right size diameter.
My computer won't go to "cycle terminal.com". My computer or a bad link?
