Running rough under load
Started by Flattsix6, Mon 08, Jun 2026, 05:19:50
Previous topic - Next topic
Flattsix6
My bike idle's fine starts fine but when put in gear and going down the road it bogs dow underload is anybody had this problem
Quote from: Flattsix6 on Mon 08, Jun 2026, 05:19:50My bike idle's fine starts fine but when put in gear and going down the road it bogs dow underload is anybody had this problem
So what have you done about this so far?  What have you ruled out?
WintrSol
Also, is the bike still in stock condition? If not, what was changed?
DragonRdr
Just throwing this out there, but how long have you had the bike and have you checked the air filter? I had the same problem some years ago and over the winter chipmunks, mice or squirrels built a nest on my air filter. Changed out the filter and good to go. Not saying that's your problem, but it's worth checking.
Rich
2000 Valkyrie Interstate
1994 Goldwing Interstate
Flattsix6
Thanks dragonRdr for that info I did find a large mouse nest in my airbox hopefully this solves the problem of it running rough when I put a load on it
DragonRdr
Quote from: Flattsix6 on Tue 09, Jun 2026, 11:22:18Thanks dragonRdr for that info I did find a large mouse nest in my airbox hopefully this solves the problem of it running rough when I put a load on it
You're welcome, glad it was helpful. I also put a can of Berrymans B12 in a fresh tank of gas to help clean out the fuel system.
h13man
No mouse nest but 1/2 can of Seafoam to fresh 5 gallon of 87 cured my sluggish high speed circuit after 125 mi./25 mpg maiden voyage. Took about 2 mi. down the road and all was good. Found out quickly why Dragon nickname exists.  ;D
