News:
Main Menu
Barnett clutch drag
Started by Gearhead24, Fri 03, Jul 2026, 11:19:51
Previous topic - Next topic
Gearhead24
Hello,
It's been a while since I've been here but I just did a massive overhaul. New timing belts, new clutch (Barnett), set valve lash, new brakes and rotors, rejetted carbs for cobra pipes, new exhaust gaskets, and a lot of cleaning.
I thought I fully bled the clutch, but when u put the bike in gear with clutch pulled the bike drags and wants to stall. I did rebuild the slave cylinder as well.
When I bled the clutch I got pressure built up and fluid smoothly flowing out the bleeder, then I tied the handle for about 9 hours while I was at work.
I used the full Barnett kit and reused my semi new damper plate, the stack height wouldn't have been the same without it.
