News:
Main Menu
Loose Radiator
Started by WillT, Sat 08, Aug 2026, 16:55:02
Previous topic - Next topic
WillT
Hey guys, noticed my radiator's a bit loose. The left mount is fine, and it looks different from the right mount, which is the loose one. I got my finger behind the right, loose mount and there seems to be some threading for a bolt or something on the inside. Tight fit, can't get a picture.
Any advice? Thanks.
bottom of radiator floats on a pin/stud on each side.  so movement is normal
ridingron
Pin probably goes into a rubber mount and the rubber is shot and/or missing.
