Saddle bag guard bolts
Started by Sixgunluvr, Tue 18, Aug 2026, 22:17:24
Previous topic - Next topic
Sixgunluvr
I recently decided to buy the rails they go behind the saddlebags since whoever had the motorcycle prior did not use them. I bought a nice set of chrome rails, but the bolts they sent seem just a hair short. Has anyone else had this problem? I'd like to get a couple bolts that are just a shade longer.
 The OEM is a nice 12 and 14mm bolt head that is also chrome these bolts don't seem as shiny and have Allen heads on them. Either way they are longer than the originals, but evidently not quite long enough. Would be nice to have the original OEM bolt heads that are longer.
  I guess I will have to measure. Add a little bit then head to the hardware store unless anybody knows exactly what size I need. If so, I'd probably try to order a couple of them online.
Sixgunluvr
ridingron
#2
Maybe stick the small bolt in the big bolt nut hole from inside the fender. Compare the amount sticking out of the fender to the amount needed to fit through the saddle bag bracket. I think most metric bolts come in 5 mm intervals. Maybe 10 mm for longer bolts. Chrome is probably the metric equivalent to 1/4" interval.
Sixgunluvr
#3
As I remember now the larger diameter aftermarket bolt was just long enough.  The smaller diameter bolt was just shy/flush with the hole. If it was the same length as the larger diameter bolt it would work.
Piper Archer #1
On my 1998 I just finished removing my bolts for those guards and I find the rear bolt (smaller diameter) is about 2-9/16" in length. This is also the bolt which must hold the rear fender in place, I am finding out now. The other front bolt (larger diameter) is 2-1/8" in length. I can't guarantee these are the OEM ones, as I am not the first owner of this bike.
Sixgunluvr
Received the correct button head bolt from the manufacture that I ordered the saddle bags guards from. All is well.  For those that prefer a bolt similar to the shorter original bolts when adding saddle bag guards, I found the correct size on eBay and they look like this. I assume they would work.
