News:
Main Menu
Maintenance
Started by jdp, Yesterday at 12:55:06
Previous topic - Next topic
jdp
If mileage is around 70,000 and up what do they recommend for maintenance? Like timing belts and fluids, I was thinking of wheel bearings too, I want to make a cross country trip next spring and don't want anything to go wrong
WintrSol
The manual stops at 24,000; says 100,000 for the timing belts.
Every 8,000: replace oil + filter, spark plugs
Every 12,000: replace air cleaner, brake and clutch fluid*
Every 24,000: replace coolant, final drive oil.
Everything else should be inspected.
*Brake and clutch fluid should be replaced every 2 years.
If you don't know how long it's been, do it now, and inspect the belts.
