Motor will stop running when put in gear.
Started by Griz Leigh, Thu 29, Oct 2026, 12:14:32
Previous topic - Next topic
Griz Leigh
2000 Interstate trike will turn over and run normally in neutral but when put in 1st or 2nd gear the motor will stop running. This happened after I had to abort the road and went on to the shoulder for a bumpy stop. No damage to the undercarriage and no leaks. Any thoughts?
Cracker Jack
Trike "thinks" the kickstand is down. That will give your issue. The bumpy ride apparently damaged whatever arrangement was made to take the kickstand switch out of the system. Probably two wires connected in the area where the kickstand used to live. :cooldude:
Thunderbolt
    ZACKLY What the other 2 mentioned. PLZ let us know what ya find out. RIDE SAFE.
Griz Leigh
Thanks guys, that was it the switch turned as if the kick stand was down. :cooldude: tie wrapped it back to up position
and runs like a like a dream.
Quote from: Griz Leigh on Fri 30, Oct 2026, 11:35:41Thanks guys, that was it the switch turned as if the kick stand was down. :cooldude: tie wrapped it back to up position
   And yer local M/C Honda dlr may Not have figured it out BUT would have indeed charged shop time!  :-X  And here all ya gotta did is ask!  :2funny:  RIDE SAFE.
GiG
Quote from: old2soon on Fri 30, Oct 2026, 14:53:11
Dealer would have replaced K/S  :coolsmiley:
Proper fix would be to wire so ECM thinks K/S is always UP-
Jumper the 2 Terminals & avoid future recurrence (matter of time until tie wrap falls and switch again becomes confused!)
Everything is - Nothing is .
(send it to OSS)
I'm putting in a call to the League Office!   🎳
