Do you have issues under load? Loses its guts at high rpm? I did
Started by calcruiser, Thu 05, Nov 2026, 15:44:11
Previous topic - Next topic
calcruiser
Who can guess what it was?  There's a reason it's the thing we check last.  Fat cake.
Mooskee
Challenger
It could be a lot of things, but LAST thing I would probably  check would be the air filter. Simply because everytime I have had mine out in the last 27 years. It has been pristine on both bikes :???:
calcruiser
Quote from: Mooskee on Thu 05, Nov 2026, 17:15:38Petcock issues?
good guess,  not it though.  it was the CDI.  went through everything else first.  because it was $275 to swap out the CDI.  had the issue narrowed down to being electrical and not fuel.  got to where it was problem was either in the wiring harness or the CDI.  ten minutes to change the CDI so eliminated that first.  and presto i'm done!  it's tough solving load problems cause you can't create load on the bench and you can't work on a bike going 80 mph.
Pluggy
Great troubleshooting!  To find a problem with a complicated motorcycle, we must have the bike right in front of us.  You did just that.
The free advisors (often on FB) are quick to recommend "Rebuild the carbs and desmog".  This would have been a costly non-solution.
