Rattlebars Kickshifter availability
Started by delucaj, Mon 23, May 2011, 10:24:35
Previous topic - Next topic
delucaj
I wonder if any enterprising VRCC members have contacted Rattlebars to inquire about a license to manufacture the kickshifter since they retired?  I know that I am not alone in searching to buy one.
toetruck21
If you find someone to make them please let me know, I would be interested in one myself.
VRCC# 32877
1999 Valkyrie Interstate Red/Black
designer
I would give it a try, but I need one to measure. No luck on getting one to look at.
2002 Valkyrie Std
K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
delucaj
designer
I can make the drawings, just need to model it. I can design one also, but easier to badge engineer.
2002 Valkyrie Std
abcdleines
Has this gone any farther??? Am very interested in one. Brett
tank_post142
i've worked up a redesign using way better bearing system and it's out for bids right now. i'll know a final price in a week or so. id like to keep it in the $150 range.(i have an in with a chromer) if it works i'll have 50 made up ahead of time and will be able to ship priority mail upon order. that was my biggest complaint, ordering and waiting, they will be pre-made and boxed ready to ship.
I got a rock :(
VRCCDS0246
I don't want one, and I don't know the difference between the rattlebars kind and
the other kinds...
Is this a good one?
The eBay description is that it is slightly bent, but if it is the right kind, it should
work as a model for a fabricator...
abcdleines
Quote from: tank_post142 on Sun 17, Jul 2011, 14:42:47
1 sold. Let me know when done. Brett
designer
Would like to see a completed one before I buy.
2002 Valkyrie Std
X Ring
Quote from: hubcapsc on Sun 17, Jul 2011, 15:10:01
the other kinds...
Is this a good one?
Mike I believe that is the MCE shifter.  The floorboards are on a separate auction.
Marty
Westernbiker
Quote from: designer on Sun 17, Jul 2011, 17:27:04
+1
Let me know when you have them.
toetruck21
+1  :cooldude:
They look and work good consider one sold!
VRCC# 32877
PhredValk
I'll take one as well. I emailed Chet on the possibilities of publishing drawings, but got no answer.
Fred.
VRCCDS0237
tank_post142
will know price and production date after inzane. i'll see you guys there  :cooldude:
I got a rock :(
VRCCDS0246
designer
Quote from: PhredValk on Mon 18, Jul 2011, 12:10:29
Fred.
Did the same thing, but didn't get a response.  So I measure one and made a cad solid.  Can supply a print if anyone is interested...
2002 Valkyrie Std
Momz
The Kuryakyn "heel/toe" shifters for the GoldWing 1500s are still available.
They can be adapted to work on the Valkyries. And they (when properly set-up) look very good and have very little slop in them.
ALWAYS QUESTION AUTHORITY!
X Ring
Quote from: Momz on Mon 18, Jul 2011, 14:25:19
They are?  I checked Kury's website and can't find them.  Do you know how to set up Kury's shifter?  I have one and it is frustrating the hell out of me.
Marty
Momz
#18
X Ring, I believe the opening was at about the 11:00 position so that it does not contact the pipes while shifting, and you will need to adjust the rod length..
I've seen several lately at two different GW specialty stores here in lower MI. May no longer be in the current catalog.
Yes, they can be frustrating to set-up. Once installed properly, they do work!
I've had both the Kury and the Rattlebars shifters but, I do prefer the CBR1100XX shift levers and have them on both my Valks.
Paladin528
Anything ever come of this?  I know it's old and all.
Flrider
You are right about the OLD thing, I started reading and then noticed the posts date  ;D
Check with JEFF K, he had some powder coated ones available last year.
paulclark911
This is too bad, it seems the few that are out there are going for twice the price as the originals. I would really like to try this, don't like toe shifting much!
paulclark911
Just found one on eBay $299.99 and $60.00 to ship it. WOW! Guess I won't be buying one.
