Carb sync, whats your numbers?
FLATSIX:
What to do then for obtaining the best performance if the idle-drop procedure will not give this?
When you turn each screw 2.1/4 turn out without the motor running, then there must be a difference from carb to carb I guess - or not?
So the best is to perform the turning with running motor at 900 rpm and then adjust each screw to max. rpm - how much turns will this give approx.?
With this procedure will it be close to 100% you think - now the Lady runs good, but I think it will be better if pilots are set optimal for each carb - or not?
I hesitate before starting to turn at the machine..... :angel:
Navigation
[0] Message Index
[*] Previous page
