The clutch repair is half done. Work in progress.....................
Started by 2tonevalk, Tue 02, Oct 2012, 11:30:15
Previous topic - Next topic
2tonevalk
Well the repair continues.  Parts are ordered.  Made my basket removal socket.  Just waiting for the parts to come in.
46 mm 12 point socket fits like a glove.
Aftermath of cutting the socket.  Still needs a little grinding.
Addition of 2 inch metal pipe joint and some nice welding.  It aint purty but she works like a charm.  :)
I hate seeing my Beast up on the jack for extended periods of time like this.  Dang!
I hated seeing you ride home alone the fast boring way with an iffy clutch from the Meet In The Middle
ride... glad you are making good progress on getting stuff fixed  :cooldude:
Daniel Meyer
While you're down there...clean up that kick-stand bolt. Add antisieze.
CUAgain,
Daniel Meyer
2tonevalk
Quote from: hubcapsc on Tue 02, Oct 2012, 11:44:03
You got that right.  My butt was kinda puckering every time I pulled on the clutch.  Thank goodness I did not do it more than a dozen time on the way down to SC.  I
I appreciate your offer to ride down with me.  But if she quit, there would not have been anything you could have done.  Thanks for the offer.
2tonevalk
Quote from: Daniel Meyer on Tue 02, Oct 2012, 11:44:51
Yep Daniel, seen that myself.  Will dope it up when I go to put it back together.  Taking it down, I was almost afraid it was gonna twist the bolt off.
If the front wheel is off the ground why is the rear wheel on the ground?
Something not very stable going on there!
LadyDraco
Robert..
I had ALL the tool to do the clutch... :angel:
IYCR .... I had to tear into  both inner and outer baskets...
You homemade tool looks like it will do the job... :cooldude:
Here a link to my work...
Clutch  TheBeast
This  is  the  way
Valkpilot
Quote from: Britman on Tue 02, Oct 2012, 13:17:22
It's difficult getting to the clutch when you lift at the balance point.  The lift has to go under the engine, which raises the front end only.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
2tonevalk
Hey Brit.  It is precariously positioned.  But that is where the jack had to be placed.  I've got it tied down with straps.  She's not going anywhere.  It's steady as a rock right now.
2tonevalk
Quote from: LadyDraco on Tue 02, Oct 2012, 13:40:11
Robert..
Clutch  TheBeast
I did not know you had the 46mm.  But this one works very well.  It was not that expensive to rebuild.  I've got about 25.00 in it.  But thanks for thinking of me.    :cooldude:
2tonevalk
Yep LadyDraco,
Mine looked the exact same as yours did.  But I did not find anything wrong with the inner basket.  But I guess i need to look closer at it for wear.  It seemed ok to me.  My outer basket looked exactly like yours though.  Cut a deep groove in uprights.
2tonevalk
LadyDraco,
Did you replace the inner basket just because or was their damage to the teeth?  I cannot find anything wrong with the inner basket on mine.
Just curious.
LadyDraco
Yes I had damage  on both inner and outer baskets...
So .. Felt it was wise to just replace them.. After all I was in there... :angel:
This  is  the  way
2tonevalk
Quote from: LadyDraco on Tue 02, Oct 2012, 17:24:58
Well if mine is damaged, I cannot for the life of me see where.  I guess I'll walk on the dangerous side.  But I've looked at it up and down.  No digs or gouges.
hal47
Glad to see it wasn't torn  up inside,looks like you have it under control Robert.
Stanley Steamer
Dohhhhhhhhh, did you check the FLUID level and condition FIRST???........ :o :o
Stanley "Steamer"
"Ride Hard or Stay Home"
2tonevalk
Yeah Hal,
I got her torn down and waiting for parts to come in from HDL.  They should be here Friday.  You were right it was a pretty simple tear down.  Just had to modify my socket for some length.
Steamer,
What do you mean fluid level???  The clutch fluid?  I did not take the clutch apart.  I just removed the 3 bolts holding the slave piston to the clutch cover and pulled it away.  If that is what you are referring to.
