bring on your little valkyrie
Started by Jess Tolbirt, Thu 08, Nov 2012, 10:45:49
Previous topic - Next topic
Jess Tolbirt
Valkyrie member # 23084
olddog1946
Don't let that one take a nap on ya..would take a crane to lift it back up.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Jess Tolbirt
you know if ya look real close there are cylinders on the other side too...i just wonder that the hp is and torque,,,and how big is the dude tat rides this thing?
grandpaweaver
needs a bigger gas tank, that one would be on reserve before the end of the driveway
Isaiah 41:10
Geesh,, I wouldn't want to pay for a set of sparklers.. 48  of them..   I'd like to see someone really try to ride it..
And the cooling fins are turned 90 degrees to the direction of travel. RIDE SAFE.
OzarkRider
It is a 48 cylinder, 4200cc engine made from s1/kh250 cylinders, by Simon Whitlock.
"Each motor is basically 8 "s1 /KH250" cylinders bolted on to cut up standard casings, with a 8 cyl built up crank, in turn they are bolted to a housing, gear linked and driven thru a BMW road bike gearbox, as the bike is pretty long already it would be difficult to put a transverse drive thru a gearbox. It has taken almost three years of hard work and he has overcome some huge problems to get here - - where do you even start to think about building a bike like this? . . . Oh, by the way, Simon is not an engineer of any kind - he oversees the building of shopping precincts etc
Don't look at it as a bike, look at it as a pure feat of engineering . . . and Simon built a Nitrous injected, fuel injected, water cooled, supercharged H1 about 5 years ago! . . . . How will he top this one? He can't - WHO CAN? I think as you say, his next project may be reverting back to a small engine and gaining the maximum horsepower from it "
"The bike has a small 75cc "Donkey" engine undr the seat to start it."
"The ignition is by 6 x 8cyl E-Type Jaguar distributers."
"Oh, and not only does it run - but it is rideable - JUST! - the engine and box alone weight just over a ton! "
http://www.home.zonnet.nl/ruiter2432/48.wmv
http://www.bigbikeriders.com/48cyl.htm
Kawasaki 48 Cylinder Runs!
97 Valkyrie Tourer
83 V65 Magna
VRCC #34495
VRCCDS #00269
"You god-cursed, mean, dirty, son-of-a-bitch!"
"I wouldn't make it a habit of calling me that, son."
"Stole It From A Whore House In Creede"
Gryphon
Do the carb sync would be a weekend project by itself.
ricoman
kinda makes a Boss Hoss look like a poser!
boss hoss bill
Poser?
We ain't no stinkin posers!
However, we dumped 8 cylinders for 6! :cooldude:
