Heat Pump freezing up........must be a leak??
Started by gordorad, Tue 01, Jan 2013, 11:02:28
Previous topic - Next topic
gordorad
Ok, it is about 22 F outside......Outside unit is freezing up.  :tickedoff: Must be low on freon again!! ARGH!!!
Should I turn the thermostat to run on EXT HEAT???  What's the best course of action?
Thanks boys!!
Support the Arts!!    www.gordonradfordphotography.com
1st thing I'd do is get the freon checked and filled if need be.
gordorad
I'm pretty sure it is low.......
But should I set the thermo to em heat setting???
Stanley Steamer
Quote from: gordorad on Tue 01, Jan 2013, 12:26:34
That will kick the electric strips on and it will heat up fast......but it's hell on the electric bill.....I'd get that freon pronto... :cooldude:
Stanley "Steamer"
"Ride Hard or Stay Home"
JWV 99 I
You may want to have a HVAC tech check into to it, I also have a heat pump.  The unit should have a sensor that reverses the flow of hot freon to the outside unit to deice the unit.
When the outside temp goes down to 20 degrees or less, most heat pump can not heat your home, the strip heaters are expensive, but will keep your home warmer. Hope this helps.
